Home » Audio » Speaker » Why won't a single driver speaker do metal?
Re: a good question [message #21158 is a reply to message #21149] Fri, 05 August 2005 12:36 Go to previous messageGo to previous message
Ed wrote:
"That is a good question.......why WOULD someone go to all that trouble when a simple OB or sealed enclosure would be so much easier to build? There MUST be a reason! And I doubt it's marketing on the part of the builders........my guess and it's only a guess.......
Efficiency, dynamics.....and to achieve a balanced response down to cut off with out sacrificing efficiency might be a couple reasons."
Ed, my guess (and I have MUCh less experience than you do) is that BLH horns are built if someone is not using a subwoofer. If one is using a sub and crossing the "full range" driver at 90 Hz or so, then I have not seen anyone use a horn.
Now, with a real low Q driver that is not really meant to produce a lot of bass, like a 3-4 inch fostex, one may need a horn to get down to even 80 -90 Hz, in which case it is totally justified. But if one is using an 8 inch full ranger, that can achieve 90 Hz in a simple BR all day long, the reason for a horn may become less obvious.
What do you think?
-akhilesh
Previous Topic: interesting auction item
Next Topic: Driver Size Thoughts
Current Time: Mon May 20 17:03:37 CDT 2024
