Home » Audio » Speaker » Klipsch RS-7 clone
Re: Klipsch RS-7 clone [message #19362 is a reply to message #19361] Thu, 27 September 2007 01:40 Go to previous messageGo to previous message
Kim Schultz is currently offline  Kim Schultz
Hi Wayne, thx for the reply.
I think I will change the design a bit though.
After looking at the Klipsch RS-62, I think it makes more sense to have a complete set of drivers on each side.
I will use two Monacor SP-6/150PA mouted in a 14-16liter bass reflex triangle shaped cabinet, that should give me a F3 of about 75hz.
For the compression drivers I think I´ll go with the new BMS 4524, it can be used down to 1900hz and is still very cheap.
The horns are not yet completely decided, but something nearly square with a 90x60 pattern is fine.
After thinking it over again, the dipole arrangement makes NO sense at all when using horn. I´ll just wire them as you suggested in a bipole arrangenment.
Previous Topic: Connecting speakers via cat6 cables to a computer
Next Topic: New Project
Current Time: Mon Jun 10 04:24:54 CDT 2024
