Home » Audio » Thermionic Emissions » 6Ah4 Amp
Re: 6Ah4 Amp [message #11331 is a reply to message #11330] Mon, 03 July 2006 16:40 Go to previous messageGo to previous message
Well, you might say the 300b is my tube of choice, because, I have a pair.
When we talk of common DHT for SET amps we, (I) mean 45, 2A3, & 330b.
I love the 45. My 45 DRD is probably the most "refined" amp I have but with my 96db speakers, they are more than sometimes, not enough. Even at very moderate volumes.
OK, flashback time. A few years back, when I thought to try the SET thing, I, as I suggested above tried it by inflicting it on my long suffering ST-70. I wired one EL34 across both sides of the output trans and let her rip. I liked it enough to pursue the idea. I had less efficient speakers back then and was used to 20-50W of P-P tubes and 250W of SS. So the 300b seemed like the only choice.
The 300b has the most output power, they say 8W into a 3.5k load. I use a 5.6k load for about 4~5W and it’s still plenty.
But the 300b is a hard tube to drive. So (in my opinion) it’s sound ,is more dependent on the input stage. I have tried .
FI, OK but soft.
SSRP, just couldn’t get it to work for me.
WE-91(6sj7) not bad at all, may well be many people’s cup of tea. If I had the money I’d try 310’s.
DRD,I was still on the 45 honeymoon, so not a fair trial, must get back to that.
And now the choke loaded D3a. This is working for me so far. What I am looking for may not be the "best". What I Want is a sense of life or emotion. Not something pure but clinical like a gain clone. (though I will not part with mine)
Some reviewer once said something like "the 300b sounds great but you always know you’re getting a show"
I was playing some James Cotton a wile ago and I was at the show.
On to the 2A3.
2.5 Watts.
If this is enough power for your speakers. It’s pretty much a ‘no brainer’ They are not too expensive and easier to drive. There are so many kinds out there both, new and old you can tune the sound a little
If you have high efficiency speakers, that’s what I’d do. If you have a 3-5K transformer you can try something else later…John
Previous Topic: Marshall DSL100 Buzz
Next Topic: Seduction done!
Current Time: Tue Jun 04 03:05:08 CDT 2024
