Home » Audio » Thermionic Emissions » Still bewildered by it all!
Re: Still bewildered by it all! [message #11061 is a reply to message #11053] Fri, 25 March 2005 19:51 Go to previous messageGo to previous message
For any given design, you can either spend next to nothing or have to mortage your home to get it built. A simple resistor can run you a couple of pennies or over $10. Now multiply that by the number of resistors in a typical circuit and you can see how material costs can differ.
What I'm trying to say is, if you're starting out, don't worry too much on the quality of parts. Breadboard the design on a piece of wood with the cheapest parts you can find and focus on getting the build correct (ie getting it to work with no hum). Make sure you like what you hear, THEN start swapping out parts with better quality components to fine tune it. If it sounds good with the cheap parts, quality components can make it even better. However, if the design sounds bad with the cheap parts, even the most expensive components can't help.
Gar.
Previous Topic: Electronluv
Next Topic: Heyboer OPT iron vs Hammond?
Current Time: Thu May 23 00:01:44 CDT 2024
