Home » Audio » Silicon Valley » DIY Digital Amp Kits
Re: 41 Hz Audio Amp 6 [message #10336 is a reply to message #10335] Tue, 18 October 2005 18:02 Go to previous messageGo to previous message
Yes, it uses the Tripath 2020 chip - 25W into 4 ohms, 12 W into 8, but those are optimistic ratings because it's distortion characteristics are much like a SET amp. More realistic ratings for under 1% distortion are 15W and 8W. With less than two hours playing time it's too early to evaluate, but it seems to have a nice clear, but slightly bright/siblant sound. I plan to replace the cheap electrolytic input caps with Northcreeks when I install it in the case, which along with some breakin time should help tame the brightness. It should be perfect for driving the 3 Pi Theaters by the time the GPAF rolls around.
Previous Topic: Has someone tried using two Sonic Impact amps?
Next Topic: customise valvestate vs102r
Current Time: Fri May 31 23:39:46 CDT 2024
