Home » Audio » Silicon Valley » Parasound A23/A23+ - class A
Parasound A23/A23+ - class A [message #94640] Thu, 21 October 2021 06:47 Go to next message
kasperbergholt is currently offline  kasperbergholt
Hi!
I'm considering buying a Parasound A23 or A23+. Several places it's mentioned that it runs in class A up till a certain point.
I've tried finding the threshold for this without success.
Does anyone here know.
Related, any one who have done measurements / knows an equation for establishing watts used in relation to DB sensitivity for specific speakers (I'm using Harbeth M301's).
Huge thanks in advance,
Kasper Bergholt
Re: Parasound A23/A23+ - class A [message #94642 is a reply to message #94640] Thu, 21 October 2021 08:56 Go to previous messageGo to next message
Speaker manufacturers often publish a specification that tells you SPL at one watt measured at one meter distance. Sometimes it is listed as SPL at 2.83v, which is the same if the speaker presents an 8Ω load.
Re: Parasound A23/A23+ - class A [message #94644 is a reply to message #94642] Thu, 21 October 2021 10:18 Go to previous messageGo to next message
I looked up your speakers at 85db @ 1w 1m.
Re: Parasound A23/A23+ - class A [message #94658 is a reply to message #94640] Sat, 23 October 2021 10:09 Go to previous messageGo to next message
Thank you for the replies, Wayne & Rusty Smile
I'm afraid my question should have been more clearly formulated.
What I'm looking for is the amount of watts when the Parasound amps switch from A class to AB class (not the sensitivity of the speakers).
It's mentioned as 3 watts here:
"Parasound A23 stays in class A up to 3 watts, I believe. Parasound A21 stays in class A up to 10 watts."
https://forums.stevehoffman.tv/threads/question-about-passive-bi-amp-and-class-a-watts.903896/
A number I cannot find more sources on.
Re: Parasound A23/A23+ - class A [message #94659 is a reply to message #94658] Sat, 23 October 2021 10:22 Go to previous messageGo to next message
I would contact the manufacturer directly. Get the information "straight from the horses mouth," as they say.
Re: Parasound A23/A23+ - class A [message #94660 is a reply to message #94659] Sat, 23 October 2021 11:31 Go to previous messageGo to next message
Doesn't the correlation between your speakers sensitivity and the number of A-watts you are concerned with come down to your listening level and program material? Do you feel that the purity of the A class will be diminished by switching into class A/B? Your speakers being of a lower sensitivity would require more watts wouldn't they to get the sound pressure level of a higher sensitivity speaker? Depending on the source say vinyl or digital, and the type of music you listen to.
Re: Parasound A23/A23+ - class A [message #94671 is a reply to message #94660] Sun, 24 October 2021 05:43 Go to previous messageGo to next message
Rusty wrote on Sat, 23 October 2021 11:31
Regarding 1) It will - but I don't think I can calculate when the shift from A to A/B happens if I don't know when the amp switches - e.g. at 2 watts or 6 or 10 (or higher).
I'll follow the suggestion of contacting the manufacturer directly Smile
Regadring 2) purity of class A. Many people do it seems. I have very limited listening experiences of pure class A (and that's primarily been tube amplifiers (Audio Note P1SE and P2SE).
John Curl answers the question in an interview in the following manner:
"All else being equal the more Class A you have the better. We don't need a
full Class A amplifier, because people don't listen to full power levels all
the time. They really need only 10 Watts or so because that is where most
of our listening is done. However, getting that 10 Watts of Class A is really
quite a feat considering of the all other constraints of having 200 Watts
Class AB in reserve. The Class A portion is always smoother and better,
while the Class AB is always a bit rougher because it is against the law of
physics. It breaks the music into positive and negative cycles and then
splices them back together."
https://www.parasound.com/pdfs/JCinterview.pdf
Thanks again for the inputs - it's appreciated Smile
Re: Parasound A23/A23+ - class A [message #94676 is a reply to message #94671] Sun, 24 October 2021 09:07 Go to previous messageGo to next message
Here's some more information on using class A from the Pass Labs you might find interest in Kasperbergholt. https://www.passlabs.com/technical_article/leaving-class-a/
I can understand you're interest in this mode of operation and it's effect on quality. I was the same about OTL tube operation. I went that route but made a commitment also with my loudspeakers and went from mid sensitivity like yours to high sensitivity to better engage with the lower wattage of tubes in general and specifically OTL tube amps. You'll probably be just fine with your choice of Parasound amp you choose. They get great user reviews. And your equally well praised speakers will need those extra A/B watts for when you turn the volume up.
P.S. I have an older 90's vintage Parasound amp I've used with home theater.
Re: Parasound A23/A23+ - class A [message #94695 is a reply to message #94676] Wed, 27 October 2021 07:07 Go to previous messageGo to next message
It's funny you mention tube amplifiers. My interest was sparked after listening to two tube power amplifiers from Audio Note (P1SE and P2), which sounded beautifully, so I considered taking that path.
Then I found out that it takes the doubling of watts to achieve an increase of 3db (if I understand the mechanisms correctly).
I downloaded a measurement app yesterday (Spectrum for iPhone). My normal listening level is around 55db measured 1 meter from the speakers on axis - with peaks up to 92db.
I'm not sure it measures correctly / is correctly calibrated. Will look more into this in the following days.
Thanks for all the inputs,
Kasper
https://bergholt.net
Re: Parasound A23/A23+ - class A [message #94697 is a reply to message #94695] Wed, 27 October 2021 09:47 Go to previous messageGo to previous message
Never heard of Dorothy Ashby and her jazz harp interpretations. Nice kind of cocktail hour smooth jazz. Interesting to hear that instrument used that way. Harpo Marx would have approved. Here's something for you if you like a bit of funk jazz and haven't taken in Tokyo Groove Jyoshi. Asian funk with a traditional twist.
https://www.youtube.com/watch?v=g46tXWxtsfY&t=177s
Previous Topic: The Intellectual People Podcast - Bruno Putzeys (Kii Audio & Hypex Audio)
Next Topic: Which is Better, Tube Amps or Solid-State Amps?
Current Time: Thu Jun 06 11:06:36 CDT 2024
