Re: Phono Preamp First Look [message #94228 is a reply to message #94225] |
Sat, 14 August 2021 21:25 |
gofar99
Messages: 1916 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, Most likely we will do both. The cost of the newer one will be a bit higher though as it uses some components that cost more and will need a larger chassis. We have not determined any prices yet as we are still beta testing. Additionally our costs to produce them are in flux now. Neither will be cheap. I don't know of any really high quality all tube phono preamps that are. We are uncertain if they will be initially offered as kits as well as built. The issue is predictability of the finished device. They have numerous components and actual soldering technique, component placement and wiring are really important. We don't want to be branded as a poor product because of a bad builder's technique.
