Wayne Parham Messages: 18709 Registered: January 2001
After you finish this project (or before, for that matter), if you want I have some shielded cable that I used when I built my IR Remote Passive "Preamp" prototypes way back when. Just ping me if you want ten or twenty feet of the stuff and I'll mail it to you.
Rusty Messages: 1106 Registered: May 2018 Location: Kansas City Missouri
Thanks both of you and Wayne specifically. Where would the shield portion go? Some ground point on the case? Still though, the design doesn't use shielded inputs or outputs, or sleeve ground. Just the single wire to the center tip. I'm not sophisticated enough to know his justification. Any idear's? If this is a chronic dilemma I'm facing. Reckon I'd give anything a try. The noise is constant, on all switched inputs, doesn't go up in loudness with volume control, or gain control. Thanks for any tips.
Connect one end to ground, whichever side is most convenient. Just leave the other end bare - Cut back the shield braid right along with the outside jacket. You might even put 1/4" to 1/2" of heat-shrink tubing over the edge where the outside jacket ends, to cover the frayed edge of the shield braid.
That way the shield is grounded, but no ground loops are created 'cause it's only connected at one end.
I did all that my meager knowledge and skills allowed. The last effort was to try a cheater plug and see if that broke the ground loop. It's in the shop with the master. He said he'd fix it. It'll be interesting to find out what the hell I did wrong. Probably something very elemental. But it escaped me going over what I did.
Finally got it back today. No charge. He said he'd goofed and left out this one last instruction from the manual that was a ground wire from one of the tubes filament. No one had pointed it out. It appears in the finished wiring picture, but I never noticed just following the instruction steps. No fault of mine. It's dead quiet now he said. And he said I did a pretty good job wiring up everything, and that he'd seen units people sent in that parts were falling out opening up the things. I'm honored. Anyway I'm too damn pooped to pop getting it set up now. I finally finished raking and mulching leaves and I need a beer and an easy chair. Yes tunes would be nice. But I'll find out tomorrow what I've been missing. The man knows his stuff, so I guess the case carries all the grounding duties. Shielding cables not needed. Hot diggity! I'll do a little write up on what I think.
Johnnycamp. I think of those old timey silent movies where everyone moved in double time. I can tell you that from my preliminary listening, this thing is a joy to behold. I haven't formulated yet how to express it in words. Just more and more of what I have enjoyed from his older products. Which I understand now why this replaces two of his legacy preamps, the grounded grid line preamp which I've used for years and the phono preamp. I'll try to do a coherent sort of short review without audiophilic blather triggering a gag reflex. Hate that crap.
