Home » Sponsored » Pi Speakers » 12pi bass horn plans
Re: 12pi bass horn plans [message #91234 is a reply to message #63735] Thu, 05 December 2019 05:48 Go to previous messageGo to next message
Papyrus is currently offline  Papyrus
hello has any one can send me the 12pi bass horn plan please ???
Thanks Very Happy
Re: 12pi bass horn plans [message #91237 is a reply to message #91234] Thu, 05 December 2019 10:04 Go to previous messageGo to next message
You've got mail!
Re: 12pi bass horn plans [message #91369 is a reply to message #63735] Wed, 22 January 2020 03:40 Go to previous messageGo to next message
bassman is currently offline  bassman
Hi.
First of all thanks for your work.
Much appreciated.
Could you send me the plans for the 12pi horn sub, in metric if possible?
Thank you.
Re: 12pi bass horn plans [message #91372 is a reply to message #91369] Wed, 22 January 2020 14:47 Go to previous messageGo to next message
You've got mail!
Re: 12pi bass horn plans [message #92008 is a reply to message #91372] Tue, 02 June 2020 10:32 Go to previous messageGo to next message
Heathkit is currently offline  Heathkit
Could I have the plans for the 12 pi please?
Re: 12pi bass horn plans [message #92011 is a reply to message #92008] Tue, 02 June 2020 10:55 Go to previous messageGo to next message
You've got mail!
Re: 12pi bass horn plans [message #92066 is a reply to message #63735] Tue, 30 June 2020 01:28 Go to previous messageGo to next message
Torsten is currently offline  Torsten
can u send me the speakerplans? are they also in metric?
Re: 12pi bass horn plans [message #92067 is a reply to message #92066] Tue, 30 June 2020 07:47 Go to previous messageGo to next message
You've got mail!
Re: 12pi bass horn plans [message #92099 is a reply to message #92067] Tue, 21 July 2020 21:55 Go to previous messageGo to next message
yperiwn is currently offline  yperiwn
Hi It would be a great honor & privelege to build this Legendary Sound Weapon ; the plans for the 12pi horn sub, in metric Please ; i am very curious about the heat disperser ,which is your patent ,if i understood well ; i would like to fit Eminence Lab12c drivers in the 12 pi ,do you have them OEM with the cooling plug ? thanks in advance
Re: 12pi bass horn plans [message #92100 is a reply to message #92099] Wed, 22 July 2020 11:13 Go to previous messageGo to previous message
You've got mail!
Previous Topic: Optional Drivers and Upgrades
Next Topic: Recessed baffle and speaker grills
Current Time: Mon Jun 17 14:25:52 CDT 2024
