DIY audio gear vs. visual gear [message #90260] |
Mon, 06 May 2019 22:25 |
Augustus
Messages: 47 Registered: April 2019
Baron |
DIYers, have you ever noticed that it's tougher to repair and upgrade visual equipment on your own than it is audio equipment? If you want a better audio setup you can always upgrade your speakers, add a soundbar, or reposition the speakers you already own to best work with the acoustics in that room. Turntables, speakers, and radios can all be repaired at home. However, if something goes wrong with your television, you pretty much have to send it off to the manufacturer or buy another one. Why is it so much tougher to work on visual equipment at home?
Re: DIY audio gear vs. visual gear [message #90267 is a reply to message #90260] |
Tue, 07 May 2019 10:23 |
Rusty
Messages: 1103 Registered: May 2018 Location: Kansas City Missouri
Illuminati (3rd Degree) |
When my lcd tv went haywire a few years back, I thought that was all she wrote. Looking online I saw quite a few video's about the power supply caps going bad, exhibiting a bulging in the top of the cap. I thought, I can replace those. But, none looked bad. I found a local source that worked on these tv's as it turned out one of the IC chips had gone bad. This thing had a multitude of tiny solder leads that was beyond my capability. Turned out I got it fixed for a little over a c-note. Better than spending a half a grand or more for a new tv. Then the volume control went crazy, going up or down all the way all by itself. Once again, looking online I found what was an easy fix. Simply disconnecting a wire that enabled the volume button on the side of the tv. Nobody gets up to use the manual volume button, so, no big deal and keeping me from spending big bucks again. Thus, it can be done to some degree. Just check your local resources and youtube.
Re: DIY audio gear vs. visual gear [message #90622 is a reply to message #90618] |
Tue, 02 July 2019 22:39 |
musicluvr
Messages: 60 Registered: December 2018
Viscount |
Augustus, since a television has both visual and audio components maybe it's just more fiddly. I'm not a DIY person and I come to this section to read and learn from you all. However, I've noticed that televisions involve different types of electrical components and lighting depending on the kind it is. LED, QLED, LCD, Smart TVs, it's just more specialized and maybe that has something to do with it.
Rusty, Smart TVs are becoming harder and harder to avoid.
