Home » Audio » General » Does The Weather Affect The Quality Of Music?
Does The Weather Affect The Quality Of Music? [message #88622] Wed, 08 August 2018 10:33 Go to next message
Jazzy is currently offline  Jazzy
I noticed that our wooden door expands or shrinks a little bit depending on the weather. Do you think that the quality of musical instruments made of wood can be affected by weather?
Re: Does The Weather Affect The Quality Of Music? [message #88638 is a reply to message #88622] Thu, 09 August 2018 17:22 Go to previous messageGo to next message
Hi, A qualified maybe. There was some information on this a long while back by the reviewers at Stereophile. When they tested stuff in the main office area in Santa Fe (8000 foot level) it was different from when tested at lower elevations. They noted also that high humidity and temperature tended to change results. This almost exclusively applies to speakers. Since then I suspect that most newer speakers are treated to avoid such issues. Temperature can still affect mechanical systems though. My direct drive turntable seems to change speed slightly based on temperature. When cold it actually runs a bit fast (about 1-2%) and requires the trim to be adjusted.
Re: Does The Weather Affect The Quality Of Music? [message #88654 is a reply to message #88622] Thu, 09 August 2018 22:06 Go to previous messageGo to next message
Malfoy is currently offline  Malfoy
This subject is something I did not know. It makes sense though because different materials react with different temperatures. What makes the turntable run faster in a cold room?
Re: Does The Weather Affect The Quality Of Music? [message #88667 is a reply to message #88654] Fri, 10 August 2018 16:14 Go to previous messageGo to next message
Hi, I don't know, but other turntables may be different. It is the only one of mine (there are 6) that does this though. Probably a calibration issue in the control circuit. This one is quite complicated, especially for its vintage. The drive and control assemblies are from a 1975 Dual 701. Once warmed up (perhaps as much a 15 minutes on a really cold day) though it is right on speed all day.
Re: Does The Weather Affect The Quality Of Music? [message #88670 is a reply to message #88622] Fri, 10 August 2018 21:34 Go to previous messageGo to next message
You got an interesting equipment there, gofar99. Most things become slow and sluggish when the weather is cold, but not your turntable.
Do you think the pressure has something to do with the elevation test that Stereophile made?
Re: Does The Weather Affect The Quality Of Music? [message #88675 is a reply to message #88670] Sat, 11 August 2018 09:29 Go to previous messageGo to next message
The speed of sound changes with temperature, pressure and humidity changes. But it's not nearly as significant as the electro-mechanico-acoustic shifts that happen at different applied power levels. So a loudspeaker's performance varies much more through its (power) operating range than through the ranges of temperature, pressure and humidity people are comfortable of using them in.
A good loudspeaker design is tolerant of parameter shifts. Components should be used well within their operating range, with drivers slightly overdamped. This way parameter shifts will not adversely affect performance.
Re: Does The Weather Affect The Quality Of Music? [message #88678 is a reply to message #88622] Sun, 12 August 2018 13:01 Go to previous messageGo to next message
If I'm understanding correctly, what Wayne just said means that the integrity of the sound is not affected by pressure or temperature with mechanical instruments. What about the wooden violin or even the regular piano, will the sound of these instruments change with different humidity, temperature, and pressure?
Re: Does The Weather Affect The Quality Of Music? [message #88681 is a reply to message #88678] Sun, 12 August 2018 18:40 Go to previous messageGo to next message
What I've said relates to loudspeakers, not musical instruments. I am proficient in the design of loudspeakers, but not musical instruments.
Loudspeakers do not depend upon panel resonance, and in fact, are designed to minimize the effects of panel resonance. So the only thing that comes into play is characteristics of the medium, which is air.
There are a lot of properties in loudspeaker design that are affected by the speed of sound, which is why I mentioned the effects of temperature, humidity and (altitude) changes in air pressure.
But these properties are only mildly affected by the changes caused by temperature, humidity and altitude, and are overshadowed by the parameter shifts from thermal changes due to power.
Musical instruments are very different. They do depend on panel resonance of the instrument body. The wood material and even the finish chosen have an effect on their sound. But this is where my experience ends with respect to musical instruments. I don't know what I would expect to change with environmental shifts. I would hope it wouldn't be too drastic though.
Re: Does The Weather Affect The Quality Of Music? [message #88692 is a reply to message #88622] Thu, 16 August 2018 03:04 Go to previous messageGo to next message
Wayne, I appreciate your explanation. Well, I guess if the people listening are there to enjoy the music, then they won't notice any difference in the sound quality of the musical instrument. For example, an orchestra performing in a park compared to the same orchestra playing in a theater will not matter to the listeners because they are there to enjoy and not to critique.
Re: Does The Weather Affect The Quality Of Music? [message #91965 is a reply to message #88622] Tue, 26 May 2020 21:32 Go to previous messageGo to previous message
Vaiger is currently offline  Vaiger
Jazzy wrote on Wed, 08 August 2018 10:33
If a guitar is treated, high quality wood, the humidity shouldn't effect it. That, and if they are in climate controlled spaces, that's better still. Instruments can be affected by weather conditions if they are poor quality and the weather conditions are extreme.
Previous Topic: An Old Telephone From.........The '50s Maybe?
Next Topic: Innovations that changed media consumption
Current Time: Sun Jun 02 11:25:20 CDT 2024
