Home » Audio » Thermionic Emissions » PSUDii tips
Re: PSUDii tips [message #8795 is a reply to message #8793] Mon, 31 January 2005 16:55 Go to previous messageGo to previous message
Hey-Hey!!!,
I suppose it depends on how the model works. I have no details about the numeric methods PSUD uses. The best results come out when I put in the numbers from the measurements I described.
On Guinevere, I had planned on using the RS trans for a seperate DC supply. Not too expensive and keeps things a bit seperate. The charging current spikes from a cap input filter tend to spread around and infect things. Some small resistive/capacitive filtering on the primary side of the filament TX ought to keep the B+ quite clean.
If I try Golf sometime, and after hitting that ball, ever find it again, I'll put it back in my pocket, consider myself lucky and call it a day.
regards,
Douglas
Previous Topic: Quick and simple formulae for Ra
Next Topic: Proud Papa Syndrome (Check out my new amp...)
Current Time: Mon Jun 10 06:35:04 CDT 2024
