Home » Audio » Room Acoustics » The appropriate absorption technology
The appropriate absorption technology [message #86008] Thu, 31 August 2017 10:59 Go to next message
bcharlton is currently offline  bcharlton
Is it true that foam isn't a low frequency absorption technology? I've seen countless articles suggesting the contrary. Either way, which is the best strategy of matching the prevailing issues with the proper absorption technology?
Re: The appropriate absorption technology [message #86011 is a reply to message #86008] Thu, 31 August 2017 13:17 Go to previous message
See the "foam versus fiberglass" thread, which is on a similar topic. But I think there's also a little more to it than just what damping material is used. There is also the configuration used, which may be more to your point. Some people use panel absorbers for bass, others use bass traps which are cavity resonance absorbers. For higher frequencies, most use open cell foam "wedges" and other similar absorbent materials.
Previous Topic: The best listening position
Next Topic: Scattering of sound energy
Current Time: Sat Jun 01 11:36:46 CDT 2024
