Home » Audio » Speaker » Small speaker flanking sub limitations.
Small speaker flanking sub limitations. [message #83791] Wed, 26 October 2016 15:08 Go to next message
jonone is currently offline  jonone
So my main speakers are quite small typical 6" plus 1" dome tweeter. I know the idea of running your mains full range with flanking subs is to have as many speakers overlapping as possible to help smooth the response.
But if your speakers are relatively small is there some actual benefit in crossing them over at 80hz etc like the AV boys do, does this increase "headroom" or just intermod distortion?
Is intermod distortion audible?
Is it plausible to roll in the flanking subs with the circa 100hz crossover but then add a 80hz shallow crossover to your mains, this way the modal transition area is still covered by the mains and the flanking subs.
If you also have distributed subs you still have up to four sources overlapping up to 80hz. (Three in my case)
I suppose you can measure the response at the seating positions and see how adding in or taking out the 80hz crossover on the mains effects the response?
Re: Small speaker flanking sub limitations. [message #83798 is a reply to message #83791] Thu, 27 October 2016 08:42 Go to previous messageGo to next message
When mains are very small like that, you really need to use subs just to prevent over-excursion of the mains. If you want to use a flanking sub approach in that case, you really need two subs per side.
The whole idea is to increase the number of sound sources in the modal region. This smooths room modes and self-interference notches. At low frequencies, smoothing is accomplished by placing subs around the room, distant from one another. At higher frequencies, where localization can occur, you want the sound sources closer together, but still not coherently grouped (like you would want in an anechoic environment).
The idea behind flanking sub placement is basically the same as an array. It reduces self-interference notches from nearest boundaries. At whatever frequency one sound source suffers a notch, the other won't and vice-versa. Since you tend to see these anomalies in the 100-200 Hertz region, blending of sound sources by a truncated array makes sense.
That's why we run helper woofers (flanking subs) up into that 100-200Hz range. They smooth self-interference and high frequency room modes, up to around 200Hz where the sound field becomes statistical rather than modal.
Re: Small speaker flanking sub limitations. [message #83799 is a reply to message #83791] Thu, 27 October 2016 09:10 Go to previous messageGo to next message
So your suggesting crossing over to subs, effectively creating a three way and then having flanking subs as well?
If the above is what you mean it definitely isn't going to happen in my room with my wife. Very Happy
Is there a reason why applying a high pass filter of 80hz to the mains and still using somthing like 150hz low pass to the flanking subs won't work?
Re: Small speaker flanking sub limitations. [message #83803 is a reply to message #83799] Thu, 27 October 2016 11:31 Go to previous messageGo to next message
jonone wrote on Thu, 27 October 2016 09:10
Is there a reason why applying a high pass filter of 80hz to the mains and still using something like 150hz low pass to the flanking subs won't work?
Sure, that would probably work just fine. It would smooth the anomalies around 100-120Hz, which is where we usually find the self-interference notch from the wall behind the mains.
Re: Small speaker flanking sub limitations. [message #83805 is a reply to message #83791] Thu, 27 October 2016 15:17 Go to previous messageGo to next message
I suppose I need to measure the response with the mains run full range vs with a 80hz high pass applied, and see how it effects the response.
The manufactures of my speakers response to the question of using a high pass filter was basically you do get intermod distortion when full range but it's not audible and for a high pass to be effective against it it would need to be over 100hz and they saw that as more of a problem.
Do you think it's worth adding a high pass to help over excursion if it doesn't effect the response Wayne?
Do you think over excursion is audible/ a real world problem or do you think it's not worth it for the smoothest response.
Re: Small speaker flanking sub limitations. [message #83806 is a reply to message #83805] Thu, 27 October 2016 15:25 Go to previous messageGo to next message
Over-excursion doesn't generally affect response. It creates intermodulation distortion. You can measure it, but more importantly, you can hear it.
So there's your litmus test: Can you hear it?
If audible, it will sound sort of like the effect fan blades have on your voice. Sort of a gargling sound. Stand very near a fan and listen to your voice. Hear that modulation? It comes from intermittent reflections causing intermittent self-interference. Now listen to your speakers with booming bass while pure vocal range tones are played. Does the bass seem to modulate the voice like the fan? If so, you have audible intermodulation distortion.
Re: Small speaker flanking sub limitations. [message #83807 is a reply to message #83791] Thu, 27 October 2016 16:07 Go to previous messageGo to next message
Thanks for the reply Wayne, can you think of a song that is good to test for intermod?
I tried listening earlier with my speakers set to full range vs 80hz crossover to my nearfield sub, the differences are quite subtle and most of that was probably how the response was changing in my room? ( haven't measured)
They do seem slightly brighter with the high pass engaged, is this the "cleaner sound " or is it just because there is less bass coming from that point?
I don't think I've ever heard modulation of vocals, my speakers are active and the bass driver is very well controlled.
Is the headroom thing a myth? I.e can a speaker actually play louder released of bass( I assume the theory is less energy is being wasted on bass) or is it that it can play louder without distortion?
Re: Small speaker flanking sub limitations. [message #83809 is a reply to message #83807] Thu, 27 October 2016 17:00 Go to previous messageGo to next message
When a speaker is excursion limited, you can increase headroom by high-pass filter because that limits excursion. That's another reason why small mains benefit from high-pass filters.
Re: Small speaker flanking sub limitations. [message #83810 is a reply to message #83791] Fri, 28 October 2016 06:30 Go to previous messageGo to next message
Okay I need to think if it's worth it.
My original plan was to use my AV amp and take the pre outs and split them with simple RCA splitters, one going to my mains getting fed a full range signal and the other going to my amp for the flanking subs, the flanking sub amp has dsp so I was going to just use that to put the low pass on the flanking subs and any eq/delay needed.
Now it means I need to get a dsp module ( probably mini dsp) to go between my mains and AV amp, because if I high pass the mains the flanking subs will also be high passed.
Re: Small speaker flanking sub limitations. [message #83811 is a reply to message #83810] Fri, 28 October 2016 10:59 Go to previous messageGo to previous message
Perhaps you could try an inexpensive passive analog high-pass filter in the preamp line going to the mains as proof-of-concept. If you like what it does, you can then move on to try more elaborate filters with a stand-alone DSP module. And even after that, you may ultimately find a simple filter is what works best and go back to your original proof-of-concept setup. The proof is in the pudding and half the fun is working through it all to find out what works best!
Previous Topic: Class d for flanking subs
Next Topic: In Wall Speakers
Current Time: Tue May 28 18:41:24 CDT 2024
