Re: 3 PI build [message #79058 is a reply to message #78971] Fri, 24 January 2014 05:15 Go to previous messageGo to next message
BFP is currently offline  BFP
Thanks Tom. Stay tuned!
Re: 3 PI build [message #79119 is a reply to message #79058] Tue, 28 January 2014 17:08 Go to previous messageGo to next message
Got all the braces and the bottom of the speaker volume installed. Putting the bracing in really stiffens the panels. You can hear the difference when you do a knuckle rap test on the sides. The resonance of the panels is much higher in frequency after they are braced.
In addition to the shelf braces I also glued in stick bracing vertically on the sides as well as across the top and bottom.
index.php?t=getfile&id=1389&private=0
A few posts back Bill asked how I was going to hold the crossover board from vibrating. The rear is securely fastened to the cabinet back. I could put T nuts in the front of the board and bolt it down from the underneath. This would be awkward for removing the board. I decided to hold it down in the front using some spring steel clips I had in my junk box. They fit under a cleat attached to the back side of the baffle and hold the board down onto the bottom of the box. This should do the trick. If not I can always bolt them down.
Heres the clips mounted on the front side of one of the boards.
index.php?t=getfile&id=1390&private=0
Here is the board up against the cleat before seating it . The cleat has a 30degree slope on the bottom to help ease seating the board.
index.php?t=getfile&id=1391&private=0
And here it is seated. The amount of force needed to seat the board is not that great but definitely holds it securely to the bottom of the box.
index.php?t=getfile&id=1392&private=0
Next up will be putting he backs on the boxes.
  • Attachment: DSCF9604.jpg
    (Size: 169.14KB, Downloaded 5347 times)
  • Attachment: DSCF9601.jpg
    (Size: 146.71KB, Downloaded 5329 times)
  • Attachment: DSCF9602.jpg
    (Size: 174.88KB, Downloaded 5345 times)
  • Attachment: DSCF9603.jpg
    (Size: 217.91KB, Downloaded 5297 times)
Re: 3 PI build [message #79120 is a reply to message #79119] Tue, 28 January 2014 18:18 Go to previous messageGo to next message
What would we do without the junk box (pile, room, garage, yard) Very Happy
Thanks for sharing your build. Nice work!
Re: 3 PI build [message #79123 is a reply to message #78971] Tue, 28 January 2014 19:27 Go to previous messageGo to next message
Great looking work! I like to see how the "other half" builds... Mine get slapped together, screwed and glued, but still, fortunately, sound great...
Re: 3 PI build [message #79124 is a reply to message #78971] Tue, 28 January 2014 19:36 Go to previous messageGo to next message
I've only built a few pairs of speakers over the years. Newform 645 cabinets, GR Research OB7's, a pair of subs and now these Pi 3s. I'm a bit out of practice as I haven't been doing much wood working in the past 2 or 3 years. The hardest part is yet to come. I always find finishing a set of speakers to be the hardest part. I'm going to paint these. I've done veneer in the past but with the size of these boxes it would be a lot of $ and time to veneer them.
Re: 3 PI build [message #79127 is a reply to message #79124] Tue, 28 January 2014 20:48 Go to previous messageGo to next message
BFP wrote on Tue, 28 January 2014 20:36
II've done veneer in the past but with the size of these boxes it would be a lot of $ and time to veneer them.
Awww, go for it...but make it easy on yourself, 4x8 sheets of NBS veneer from Tape Ease and contact cement. One sheet does it if you paint the backs.
I've done PPR, hide glue (lots), yellow heat bond(sucks!) and even 3M spray-on (disaster) on backed and raw veneer; contact has worked and held up best for me.
Don't do this:
index.php?t=getfile&id=1394&private=0
Do this Smile
index.php?t=getfile&id=1393&private=0
Re: 3 PI build [message #79162 is a reply to message #78971] Thu, 30 January 2014 05:05 Go to previous messageGo to next message
Those boxes look great in veneer Bill. I am still staying with the black paint. I've done this before on an equipment stand and it has held up remarkably well over 15years of use. A top coat or 2 of water based polyurethane has proven to be a tough finish that is easy to apply. These speakers will be in my dedicated listening room and don't need to have a furniture grade finish. My thought was that the black will look nice with the black horn and woofer. We'll see.
Re: 3 PI build [message #79195 is a reply to message #78971] Fri, 31 January 2014 17:16 Go to previous messageGo to next message
Back panels glued on. I used a couple of screws in the centre at the Baltic Birch window braces to make sure the back was pulled in tight.
index.php?t=getfile&id=1395&private=0
Next I added some temporary feet so i could move the boxes around easier for painting etc.
index.php?t=getfile&id=1396&private=0
I installed the 4 magnet washers into the front panel just below the surface. Sorry for the blurry photo. The magnets will be in the grills. I got these at Lee valley. They have sets of 4 magnets, cups and washers in various sizes. These are 1/2". The weight of the grill will be sitting on a plinth attached to the lower front of the speaker so the magnets only need to hold the grill in against the baffle.
index.php?t=getfile&id=1397&private=0
Here is a box with a plinth installed.
index.php?t=getfile&id=1398&private=0
  • Attachment: DSCF9622.jpg
    (Size: 134.33KB, Downloaded 5174 times)
  • Attachment: DSCF9621.jpg
    (Size: 187.31KB, Downloaded 5162 times)
  • Attachment: DSCF9618.jpg
    (Size: 89.93KB, Downloaded 5139 times)
  • Attachment: DSCF9633.jpg
    (Size: 159.65KB, Downloaded 5178 times)
Re: 3 PI build [message #79227 is a reply to message #79195] Sun, 02 February 2014 12:21 Go to previous messageGo to next message
Amazing! You are very skilled with the carpentry!
Great looking speakers!
Re: 3 PI build [message #79302 is a reply to message #79227] Wed, 05 February 2014 10:01 Go to previous messageGo to previous message
Thanks. It's been a while since I tackled a major project. DIY speakers are a bit of a gamble and an experiment. We'll see how this one works out.
Next Topic: Happy Pi Day
Current Time: Tue Jun 04 05:55:45 CDT 2024
