Home » Sponsored » Pi Speakers » Insulation inside of speaker: Spray Foam?
Re: Insulation inside of speaker: Spray Foam? [message #76253 is a reply to message #76252] Tue, 09 April 2013 20:49 Go to previous message
dheflin44 wrote on Tue, 09 April 2013 19:51
What about stuffing the middle of a sealed sub cabinet to lower Q? Is fiberglass the best material for this?
That's an often suggested method of increasing effective volume. I don't see any harm in doing that at all. Not sure I'd depend on the "increase" as much as just making the box bigger, but if you're basically going for an overdamped alignment like something towards infinite baffle, I'd probably go for it. Can't hurt, especially if you'd really rather have a little bigger box anyway, but can't for space constraints. And yes, I think fiberglass would be the best stuff to use.
Previous Topic: 2Pi Tower Plan
Next Topic: 4pi Dinner Theater Update
Current Time: Tue Jun 09 05:04:37 CDT 2026
