Wayne Parham Messages: 18698 Registered: January 2001
zheka wrote on Tue, 31 July 2012 16:48
If I want to flush mount, should I use 1" MDF panel for the front baffle or 3/4" panel is adequate in your opinion? Given that the recess is 1/4" deep.
What I like cabinetmakers to do is to cut a ring that surrounds the baffle cutout both for the midwoofer and tweeter. This ring can be cut from scrap wood, and is only there to provide some extra thickness in the area where the router cuts into the baffle. Glue it in place behind the baffle, and install the T-Nuts or threaded inserts into it.
dheflin44 Messages: 47 Registered: November 2012 Location: Carrollton, TX
Sorry to belabor this, but I want to be sure to get the baffle recesses right. In the H290C picture below, it looks like the corner radius is about the same height as the top and bottom flanges which are about 0.8", right?
