Home » Audio » Craftsmen » Wires up the wall - looking good
Wires up the wall - looking good [message #70470] Fri, 16 December 2011 16:44 Go to next message
LoveJB is currently offline  LoveJB
We are adding speakers in one room (ceiling) and a ceiling fan in another room. We don't want to tear apart the walls so we are using a rubber like casing up the wall to hide the wires. So far it's looking good. My daughter wants to paint the one in her room. I wonder if it will hold the paint?
Re: Wires up the wall - looking good [message #70478 is a reply to message #70470] Fri, 16 December 2011 18:51 Go to previous messageGo to next message
Let us know how that works out. Pics too, if possible.
Re: Wires up the wall - looking good [message #70501 is a reply to message #70478] Sun, 18 December 2011 13:56 Go to previous messageGo to next message
Hi, I haven't seen the rubber things, but there are various versions of plastic and metal surface mount "conduit" available. They are paintable. They have all sorts of angles, corners and fittings to suit most uses. You may wish to check them out if you aren't too far along.
Re: Wires up the wall - looking good [message #70575 is a reply to message #70501] Thu, 22 December 2011 14:33 Go to previous messageGo to next message
This beats trying to run wires inside the wall. A lot of building codes require fire breaks in between studs. These are just 2 x 4s, but good luck getting through one if you are dropping wire down between two studs.
Where's a good place to buy these wire conduits?
Floyd
Re: Wires up the wall - looking good [message #70577 is a reply to message #70575] Thu, 22 December 2011 19:10 Go to previous messageGo to next message
Hi, Home Depot and Lowes locally have them.
Re: Wires up the wall - looking good [message #71129 is a reply to message #70470] Mon, 30 January 2012 00:36 Go to previous messageGo to next message
spinright is currently offline  spinright
Sounds rad! Please do post pictures when it's done, it would be great to be able to see how the finished project looks. My wires are all over the place. Crying or Very Sad
Re: Wires up the wall - looking good [message #71146 is a reply to message #70577] Mon, 30 January 2012 17:49 Go to previous messageGo to next message
Yes do post some pics. I want to see how to do mine.
Floyd
Re: Wires up the wall - looking good [message #74986 is a reply to message #70470] Mon, 17 December 2012 17:59 Go to previous message
I'm replying again because I recently moved into a house we had built. I had to do a lot of drilling and stapling, but I got all the cabling in. HDMI, RCA, and speakers for a 7.4 system before the drywall went up. Also special lighting for behind the screen and over the reliners. The .4 was to accommodate the 4 subs that Wayne P. recommends.
It only took 40 years to do it right, but it looks really clean.
Floyd
Previous Topic: DIY Car Stereos: Worth the Effort?
Next Topic: Making printed circuit boards
Current Time: Sat Jun 01 23:17:50 CDT 2024
