Home » Sponsored » Pi Speakers » TAD TD-4001 Passive Crossover Suggestions Wanted!
Re: TAD TD-4001 Passive Crossover Suggestions Wanted! [message #70685 is a reply to message #70678] Fri, 30 December 2011 09:25 Go to previous message
My best advice would be to follow the suggestions in the thread below:
In particular, pay attention to the notes, video and schematic in this thread:About ten years ago, I made two versions of the four π loudspeaker with the TAD 1602. One used the 2001 compression driver and another used the 4001 compression driver. The 2001 variant was crossed where directivities matched, but the 4001 was crossed a little lower sort of "forcing" the pattern collapse in the crossover region. Note that both crossovers were designed specifically for the horn used and the loudspeaker layout they were being used in. This is a key aspect.
The schematics mentioned in this thread are what I would consider starting points, in that they are very close to what you will want for many drivers when the loudspeaker is designed similar to the configuration I use. That is to say horns mounted on 90° waveguides or radial horns having approximately 40° to 60° vertical beamwidth at HF. You can see an example of this type of crossover, along with a lot of information on how to optimize it in the link above. This approach is described in some detail in the following whitepaper:
Previous Topic: mid horn box size?
Next Topic: 6 pi plans
Current Time: Tue Jun 09 16:31:32 CDT 2026
