Re: 4 Pi Home Theater Build [message #68184 is a reply to message #68172] |
Tue, 14 June 2011 14:58 |
NWCgrad
Messages: 143 Registered: March 2010 Location: Frederick, United States ...
Master |
Wayne Parham wrote on Mon, 13 June 2011 21:28 |
God, Phnom Penh. I still remember the 1970s when Phnom Penh was in the news all the time.
My father-in-law did three tours in 'Nam (Army grunt), when I asked if he was going to come visit his response was #%% No! Pol Pot did a lot of damage to the country before the Vienamese finally invaded and removed him from power. Country still seems pretty shakey, but they seem to be coping with their traumatic history.
Hopefully my 24 months in country will be uneventful.
VIRIBUS MARI VICTORIA
Re: 4 Pi Home Theater Build [message #68186 is a reply to message #68185] |
Tue, 14 June 2011 16:48 |
NWCgrad
Master |
Will do...your speakers will be exposed to a whole new demographic. Hopefully I can pick up an inexpensive tube amplifier while in SE Asia. I know the nOrh SE-9 integrated amplifier is made in Bankok, Thailand which is only about 300 mi away.
Re: 4 Pi Home Theater Build [message #68205 is a reply to message #68186] |
Thu, 16 June 2011 22:13 |
NWCgrad
Master |
Made a lot of progress today, will have them ready for shipment by end of weekend (I was able to come home early this week from Newport to prepare the house for moving).
First, routered the edges of the oak trim glued to the front panel. The oak strip was both thicker and wider than the intended space to account for "variations."
After flush trimming the oak the speakers looked MUCH better, I was a little concerned about the process but it worked great. A little woodfiller and a lot of sanding followed.
Attachment: 002-cropped.jpg
(Size: 155.47KB, Downloaded 7334 times)
Attachment: 003-50.jpg
(Size: 151.95KB, Downloaded 7422 times)
Attachment: 007-cropped.jpg
(Size: 101.76KB, Downloaded 7449 times)
Attachment: 008-cropped.jpg
(Size: 154.33KB, Downloaded 7411 times)
Attachment: 010-50.jpg
(Size: 116.85KB, Downloaded 7454 times)
Re: 4 Pi Home Theater Build [message #68207 is a reply to message #68206] |
Thu, 16 June 2011 22:23 |
NWCgrad
Master |
Finally, two coats of primer (first coat white and second coat gray). Starting to see the light at the end of the tunnel.
Tomorrow - or Saturday - will veneer the cabinets. Going to try the "Better Bond Titan DX™" Contact Cement from veneersupplies.com. Since most of the work is in my home theater I wanted to avoind VOC's, reviews of Titan DX on the net have been good, so I decided to go for it. Also, need to sand the primer and add a third coat.
The plan is to paint the front/rear baffles and stain/seal the veneer once I arrive in Cambodia, not enough time for paint/polyurethane to cure before they will be packed for shipment.
Attachment: 020-40.jpg
(Size: 106.83KB, Downloaded 7442 times)
Attachment: 01940.jpg
(Size: 84.44KB, Downloaded 7428 times)
Attachment: 023-50.jpg
(Size: 170.16KB, Downloaded 7579 times)
(Size: 170.16KB, Downloaded 7534 times)
Re: 4 Pi Home Theater Build [message #68245 is a reply to message #68244] |
Sat, 18 June 2011 19:47 |
NWCgrad
Master |
I have not veneered before and am not sure whether there is a particular order to gluing the sheets to the cabinet. I am planning on starting with the bottom, then both sides and finally the top. Is this order correct? If not, what is the best order?
Will use router with a new flush cut bearing bit to trim.
Thanks for the assistance!
Re: 4 Pi Home Theater Build [message #68250 is a reply to message #68245] |
Sat, 18 June 2011 23:04 |
Messages: 18698 Registered: January 2001
Oh, wow, that push-out will help with your schedule.
I am not a woodworker, don't even play one on TV, and tend to defer to those that I trust like Epstein. But I have dabbled a time or two with finishing, and I do the sides that won't be seen first (bottom and back) and then the sides, top and front. Same order you said. My reasoning is the last surfaces get the "final" attention, so they are probably going to be the best. I have no idea if that is what the woodworking pros do or not, so in this case, I'm not sure it's worth 2¢. Just a thought.
