Home » Sponsored » Pi Speakers » Three 4Pi's in Basic Black for Home Theater Build Thread
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63900 is a reply to message #63890] Sat, 21 August 2010 18:25 Go to previous messageGo to next message
Looking good. You are in the home stretch now. All of the time consuming parts are finished.
The recessed portion for the horns look perfect. Did you take the time to make a template for the router?
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63901 is a reply to message #63900] Sat, 21 August 2010 21:08 Go to previous messageGo to next message
Nichol1997 wrote on Sat, 21 August 2010 18:25
Thanks Nick, I know I talked about it but I tried cutting the cutout for the horn with a jig saw and I had pretty good luck. If I was setting up to crank out the cabinets on a volume basis I would have a template for sure.
So here is what I did. I started with a two piece front baffle. 3/4 and 1/2.
I cut the horn and port cuts with a jig saw with the two pieces separate. I cleaned up the cuts with a file and sandpaper. I also used two different blades one blade that had a much longer profile and a blade intended for tight radius cuts for just the horn corners on the 1/2. I first cut the two top cut-outs in the 1/2 then I screwed the two pieces together from the back. I then marked where the holes were on the 3/4 and drilled the 1/8 center pivot hole for the woofer through both layers.
I took the two layers apart and finished all the holes with the jig and router. Then I put the two layers back together using green glue between the layers. I used the previous screw holes to align the two layers.
The one last step was to take a little more out of the woofer recess and I used a dado guided clean-out bit to make quick work of that. (Woodline)
I made the outer 1/2 inch layer over-sized 1/8 inch all around so that I had some margin for error and after assembly I trimmed it off with a flush cut bit (Just like you showed me!)
The one thing I would do differently would be to intentionally undercut the port hole in the outer 1/2 baffle and then finish it off once the port was glued in behind it. That would make the area where they are joined a little cleaner and you could work a little faster if you just need a rough cut.
Ordering the Crossover parts from PE was a bit of a challenge.
The superior cap was on back-order and I took the last 8 (of the 9 I needed) of another. They also ommitted slipping the dummy load resister in the box. So it took a 20 minute phone call and I should have everything I need when I get home next week. I am using your design for the hook-ups.
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63917 is a reply to message #63366] Thu, 26 August 2010 19:25 Go to previous messageGo to next message
They're BLACK.
http://www.PiSpeakers.com/DIY/BigmouthinDC/BigmouthinDC_4Pi_HomeTheater_13_ReadyForAssembly.jpg
Used two coats of Duratex with some light sanding with 400 grit after coats. Used a foam cigar roller intended for smooth finish. The result is a subtle texture. Just what I wanted. Now on to the crossovers.
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63918 is a reply to message #63917] Thu, 26 August 2010 21:18 Go to previous messageGo to next message
Those look really great. Not long now...
I love your stage lettering, by the way. Very cool!
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63919 is a reply to message #63918] Thu, 26 August 2010 22:39 Go to previous messageGo to next message
Thanks, Stage?
It is the bar at the back of my theater space. I'm still working on some concepts for the back-splash design. I get a lot of feed back on the lettering. They are basically metal laminate faced 1 inch thick gator foam letters. Most commercial sign shops can get them. I have some LED strips mounted behind some molding on the ceiling that light up the letters.
http://www.PiSpeakers.com/DIY/BigmouthinDC/BigmouthinDC_4Pi_HomeTheater_14_Concessions.jpg
http://www.PiSpeakers.com/DIY/BigmouthinDC/BigmouthinDC_4Pi_HomeTheater_15_LightedBar.jpg
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63920 is a reply to message #63919] Thu, 26 August 2010 23:29 Go to previous messageGo to next message
Oh, I see now, that's a bar at the back. Now I visualize what your theater room layout looks like. I just was picturing your room wrong and thought we were looking at the screen area in the photo from a few posts back. I remember now, the screen area was shown in your first post, shown again below.
Really diggin' your theater room. Looks great, really great. It's getting ready to sound great too. Cool
http://www.PiSpeakers.com/DIY/BigmouthinDC/BigmouthinDC_4Pi_HomeTheater_01_Screen.jpg
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63926 is a reply to message #63366] Sat, 28 August 2010 13:18 Go to previous messageGo to next message
So I wired up the three crossovers, used some scrap flooring and split the High and Low sections. Not pretty, I hope they work. Tested them all with the drivers attached and they measured 5.8 ohms.
http://www.PiSpeakers.com/DIY/BigmouthinDC/BigmouthinDC_4Pi_HomeTheater_16_Crossovers.jpg
One little detail, those bright shiny edges on the JBL speakers weren't going to cut it behind the screen. So I masked them and painted them. Cut some strips from a file folder and inserted in the slot that existed between the felt gasket and the metal rim. Taped the sides and laid paper towels on the cone.
http://www.PiSpeakers.com/DIY/BigmouthinDC/BigmouthinDC_4Pi_HomeTheater_17_PaintingBeautyRing.jpg
Gave it a shot of Krylon ultra flat black.
http://www.PiSpeakers.com/DIY/BigmouthinDC/BigmouthinDC_4Pi_HomeTheater_18_PaintedBeautyRing.jpg
here is a comparison before and after
http://www.PiSpeakers.com/DIY/BigmouthinDC/BigmouthinDC_4Pi_HomeTheater_19_BeforeAndAfter.jpg
Hopefully my next post will be the finished speakers.
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63928 is a reply to message #63926] Sat, 28 August 2010 18:01 Go to previous messageGo to next message
Yeah, I was wondering what you were going to do about those shiny edges. I expected you would want to paint them. Smile
A word of warning, if you really put the power to these, the resistors in the tweeter circuit can get pretty warm to the touch. I saw that you used what appears to be an adhesive. It's probably OK, and even if it got hot enough to melt the adhesive, that probably wouldn't do anything bad. But I did want to put a bug in your ear about it. I've had the resistors melt plastic nearby when used at high power levels for extended periods of time. It will burn right through a wire tie, for example.
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63929 is a reply to message #63928] Sat, 28 August 2010 18:14 Go to previous messageGo to next message
Thanks for the tip on the resisters. When I install the crossovers I'll make sure that if they come loose that nothing bad can come from it. I was planning to mount them on the bottom, so gravity will pretty much not be a factor. Will it be a problem to put the insulation in contact with the resistors?
Re: Three 4Pi's in Basic Black for Home Theater Build Thread [message #63933 is a reply to message #63929] Sun, 29 August 2010 09:57 Go to previous messageGo to previous message
No, I haven't had any trouble with fiberglass insulation. I've layed it right on the resistors for years without having any problems. I've never tried to burn the stuff to see how it acts but it is made of recycled glass and sand so I wouldn't expect it to burn.
Previous Topic: 8 Pi Plan Request
Next Topic: Suggestions for FAQ
Current Time: Tue May 28 15:22:37 CDT 2024
