Home » Audio » Speaker » My speaker cracks!!
My speaker cracks!! [message #63707] Thu, 05 August 2010 21:27 Go to next message
Soundbuzz is currently offline  Soundbuzz
Hi I have a problem with my right channel speaker! It starts to crack terribly when I turn the volume or bass (especially) higher.
Do I have a faulty speaker? Or am I able to troubleshoot this? With little knowledge, should I even attempt to troubleshoot the problem is that's the case?
The lunatics are in the hall.
Re: My speaker cracks!! [message #63711 is a reply to message #63707] Fri, 06 August 2010 00:22 Go to previous messageGo to next message
Sounds like the voice coil is rubbing against the cone. This happens when the glue gets overheated and melts. Try gently pushing the diaphram, but gently!. If you hear nothing, then there is another culprit. If you hear any scratchy noises, that will pretty much confirm it. If it sounds like broken glass, then you blew out the voice coil unfortunately.
And why not take the driver out and take a look? That can't hurt anything.
If I were you I wouldn't take my word for it. I could be dead wrong. Let's see what the other people say.
Re: My speaker cracks!! [message #63823 is a reply to message #63711] Wed, 11 August 2010 07:57 Go to previous message
BigMacAndCheese is currently offline  BigMacAndCheese
You mean it is crackling when you turn the knobs? Have you tried cleaning the area around them? Buy an air can and give it a go. Or try swapping the speaker wires.
Previous Topic: How Many Speakers For A Home Theater System?
Next Topic: DBX "Soundfield" 1A speaker questions
Current Time: Wed Jun 10 05:09:19 CDT 2026
