Home » Sponsored » Pi Speakers » What should i buy: Pi Seven/JBL drivers or a Klipschorn?
What should i buy: Pi Seven/JBL drivers or a Klipschorn? [message #51819] Thu, 14 February 2008 03:59 Go to next message
dtor is currently offline  dtor
Hi
I wonder should i buy a pair of two yrs old Pi Seven's (all three drivers are JBL's with a high performance crossover) or a pair of stock but 23yrs old Klipschorn's? Which one of these two sets has a better sound, which one would be a better buy?
Thanks a lot
dtor
Klipschorn vs seven π cornerhorn [message #51822 is a reply to message #51819] Thu, 14 February 2008 12:33 Go to previous messageGo to next message
I think the Klipschorn is a fine speaker that sounds good in spite of its warts. It was designed in the 1940's. That's impressive to me, all by itself.
On the other hand, a folded basshorn used to 400Hz is not a good idea. Middle "C" on a piano is 260Hz. Think of that. You have most of the fundamental range of voices going through all that wood in the passageways of a Klipschorn. That's what makes voices sound kind of resonant in a Klipschorn. The panels become a sounding board, making voices sound unnatural.
This and other things have been improved using the π cornerhorn design:
  • Woofer is acoustically closer to midrange for better integration
  • Midhorn is larger and allows lower crossover
  • Midhorn covers the entire vocal range
  • Midhorn/tweeter crossover is optimized for better summing
  • All horns provide constant directivity of 90°
  • Crossover is optimized to maintain constant directivity through crossover regions
  • Reverberent field is more uniform because of constant directivity
Re: Klipschorn vs seven π cornerhorn [message #51825 is a reply to message #51822] Thu, 14 February 2008 22:42 Go to previous message
Wayne your answer was very helpful and I thank you very much for it
All the best
dtor
Previous Topic: 12 Pi v2
Next Topic: Pi speaker highs
Current Time: Sat May 31 09:49:43 CDT 2025
