Home » Sponsored » Pi Speakers » pi 4 theater question
pi 4 theater question [message #51089] Mon, 14 May 2007 06:30 Go to next message
gabbe is currently offline  gabbe
hi wayne,
i managed to get a pair of 2226, i know what to do with the box , can u please let me know what should i do with my x over?
thanks
zeno
Re: pi 4 theater question [message #51092 is a reply to message #51089] Mon, 14 May 2007 11:30 Go to previous messageGo to next message
Just remove the Zobel (R3 and C5) and the 10uF capacitor (C4) from the woofer circuit.
4 Pi pro with JBL 2226 [message #51093 is a reply to message #51089] Mon, 14 May 2007 11:31 Go to previous messageGo to next message
spkrman57
Zeno,
With the 2226 a 1.6khz crossover is recommended.
For 2226H - .7 mh coil
For 2226J - 1.4 mh coil
3rd order hi pass w/HF EQ per Pi speaker crossover.
Wayne can provide the exact schematics if you ask him.
Regards, Ron
Re: pi 4 theater question [message #51094 is a reply to message #51092] Mon, 14 May 2007 11:33 Go to previous messageGo to next message
spkrman57
Wayne,
I guess I posted same time as you and I guess I did not see the real question Zeno needed answered.
You seem to have it wrapped up!
Ron
Re: pi 4 theater question [message #51096 is a reply to message #51094] Mon, 14 May 2007 11:37 Go to previous messageGo to next message
Wow! Yeah, it looks like we posted around the same time. Thanks for posting!
Re: pi 4 theater question [message #51097 is a reply to message #51092] Mon, 14 May 2007 12:16 Go to previous messageGo to next message
thanks wayne,
it is so easy, i will do it over the week end
cheers
zeno
Can I do the same with JBL2225 [message #51101 is a reply to message #51092] Tue, 15 May 2007 04:02 Go to previous messageGo to next message
Kim Schultz is currently offline  Kim Schultz
I did the same with the 2225H woofer in a temporary 4Pi clone, but when I run the auto eq. in my surround receiver, it eq´s 2khz and 4khz about 6-8db down.
I think the 2225 needs a second order filter.
Re: Can I do the same with JBL2225 [message #51103 is a reply to message #51101] Tue, 15 May 2007 11:08 Go to previous message
You're right that the 2225 generates less output above 1kHz than the 2226. You really can't use the 2225 up as high; Best to crossover the 2225 below 1kHz. It's a good woofer for a seven π, but isn't suitable for a four π speaker, at least not without making crossover changes to lower the crossover point.
Previous Topic: h290 bolt size
Next Topic: schematic of the x over
Current Time: Sat Jun 08 11:33:14 CDT 2024
