Home » Sponsored » Pi Speakers » Say Wayne; What Do You Mean BY Wood Tweeter Horn?
Say Wayne; What Do You Mean BY Wood Tweeter Horn? [message #49898] Sun, 20 August 2006 10:41 Go to next message
Is this a horn loading a conventional dome tweeter or an actual compression driven HF horn? And what series will the horn be part of? The Pro series?
Wood tweeter horn [message #49900 is a reply to message #49898] Sun, 20 August 2006 12:40 Go to previous messageGo to next message
If you're talking about the wood horn my cabinetmaker is doing, it's a tweeter horn for compression drivers made out of wood. It's the same kind of thing that Martinelli and I worked on a few years back, but the new one has curved top and bottom walls and (nearly) straight side walls - A radial flare. It's 15" wide, 9" tall and 8" deep.
Re: Wood tweeter horn [message #49902 is a reply to message #49900] Sun, 20 August 2006 15:56 Go to previous messageGo to next message
Is that the HF for the Premium 3PI?
Re: Wood tweeter horn [message #49904 is a reply to message #49902] Mon, 21 August 2006 08:28 Go to previous messageGo to next message
The tweeter horn can be used on any model that uses a compression horn tweeter. That includes all models but the Studio one π, two π, two π tower and Professional three π loudspeakers.
Give us the "pitch"... [message #49905 is a reply to message #49904] Mon, 21 August 2006 18:37 Go to previous messageGo to next message
Greggo is currently offline  Greggo
Wayne,
I seem to recall a little more excitement and detail leading up to the launch of certain speaker models, mid horn, and bass horn... I think others would share my enthusiasm in learning more about your plans for this horn tweeter. If you are being careful with competitive issues, that is fine, but if not....
1) Good options for high efficiency tweeters seems hard to come by, I recall you will only be selling these as complete horns rather than kits. Is this just the horn or horn plus a driver that you intend to market?
2) Tell us a little about what inspired you to come up with something specific here, anything that in your mind makes this offering a bit different from the other options out there?
3) Have you done any prototype testing with any specific compression drivers? Plan on recommending the same compression drivers that are part of your kits now or are there others you would recommend for use with this horn?
4) What frequency range do you feel is the best fit for your new horn tweeter?
5) Price plan/options, if still waiting for details on manufacturing costs, then at least a ballbark or range based on what you know thus far?
I think there is a good chance I will be ordering a speaker kit from you soon, and even if I don't, then there is a good chance I will order this tweeter (combo?) horn as part of my own diy project, that is assuming you can convince me (and it normally doesn't take much...) that this is a smoother, more dynamic, and more readily integrated with the directivity at crossover of a mid horn or a 10-12 inch pro woofer/midrange cone driver.
Come on Wayne, don't be humble, get us fired up over this latest project of yours!!!
Regards,
Greg Jensen
Asheville, NC
Re: Give us the "pitch"... [message #49906 is a reply to message #49905] Mon, 21 August 2006 22:17 Go to previous messageGo to next message
Thanks for the questions - I'm really excited about the tweeter and would love to go on and on about it. But I don't want to get excitement started without being able to follow up. That's why I've had my cards close to my chest.
If interested, I'll tell you the story. I could just tell you the technical details, but that doesn't explain things very well. So if you have a minute, read on.
Set the clock back about five years when Bill Martinelli and I met. I wanted to have a vendor in the USA that made nice wood radial horns. Yuichi Arai made beautiful radial wood horns, but he was in Japan and I'm not sure they were for sale anyway. Fostex made them and so did TAD, but the prices were high. So I was looking for someone that would make fine wood horns, and Bill Martinelli stepped up to the plate.
Bill and I had many discussions over the next few months, and I did a couple dozen Hornresp models to find throats and flares that would work best, with the constraints of what could be made on a lathe. That was the biggest problem really, the fact that the lathe set limits and the throats needed to have certain dimensions. So we quickly kicked out ones that weren't suitable and settled on the best ones. That left the rest of the flare, and I wanted a radial flare with certain area expansion rates.
What Bill eventually sent me was very close, but instead of having straight side walls and curved top and bottom walls, it was reversed having curved sides and a straight top and bottom. But its measurements were good and I thought it sounded nice too. So in spite of the fact that the shape was different than what I wanted, I used and recommended them.
Eventually, Bill was making all of my speakers for me. Most people bought kits and did their own DIY thing, but those that wanted finished loudspeakers got boxes made by Martinelli. We did that for a few years, and I think everyone enjoyed the arrangement.
Fast forward a few years. Bill got busy or whatever and decided he couldn't build cabinets for me anymore. I think he may still build loudspeaker cabinets on occasion, but they're very expensive. I can understand - It's a lot of work to make loudspeakers, especially when you are meticulous with your work.
So that left me to find another cabinetmaker. I eventually settled on Brad Smith because he does excellent work. He had done a lot of custom cabinetry work in some of Tulsa's finest multi-million dollar homes, and his work was outstanding. So I knew I wanted him to do our cabinets from the first time I met him.
Brad's first project for me was midhorns, and he quickly developed flat-pack kits that are cut on CNC machines and use Miller dowels for assembly. I was impressed with his resourcefulness and the quality of the flat pack kits. Assembly for DIY builders was much easier than earlier kits and the quality was better too because of the CNC cuts. Since then, he's filled plenty of orders for finished loudspeakers and each one has been a work of art.
Last year, Brad and I started talking about the tweeter horns. I told him what I originally wanted and showed him the drawings. We started planning to make them on CNC, hoping to have them ready by GPAF 2006. That was my plan, to unveil them at GPAF.
But another very ambitious project was also in the works, and that was the 12π basshorn subwoofer. I finished the design and preliminary tests late summer / early fall and did the Prosound Shootout in October. I expected it to do well, but it really exceeded my expectations. So that sort of derailed us, both Brad and me, because now I have Brad making 12π basshorns and he doesn't have time to do some of the other projects for me that I'd like. Paying customers have to come before new development work.
So that brings us up to date. Brad and I talk about the tweeter horn every time we see each other. We make a firm committment to get back to work on them, to clear off time for him to be able to setup the CNC to make the pieces. But then we look at the orders in front of us, and put it off another month.
Sometimes I think maybe it's time to bring someone else in to help out. We've done that a couple times to help with 12π's, so maybe we'll do it again now.
I know this, I know that I really want to get moving on the wood tweeter horn and also on the 9π, which is another project I'm chomping at the bit to do. Both are completely designed and look fabulous on paper, so I'm confident the finished models will be great. I'm very eager to have them both done and ready to show. But until they're ready or at least close, I don't want to publish preliminaries and get excitement started. When I'm sure I'm only a month or two out, I'll post an announcement here.
Re: Give us the "pitch"...9π ??? [message #49907 is a reply to message #49906] Tue, 22 August 2006 12:43 Go to previous messageGo to next message
pstollie is currently offline  pstollie
9π?? Any description?
Re: Give us the "pitch"...9π ??? [message #49908 is a reply to message #49907] Tue, 22 August 2006 15:57 Go to previous messageGo to next message
The 9π is a top box for the 12π. It has a 15" JBL 2226 or Omega 15 midbass driver on a simple straight-sided 32" long horn having 28"x28" mouth, 7.5"x7.5" throat, 800in3 front chamber and 1200in3 rear chamber. It also has a 10" JBL 2012 or Delta 10 midrange driver on a 16" long straight-sided horn with 18"x18" mouth, 4.5"x4.5" throat, 33in3 front chamber and 80in3 rear chamber. The tweeter is a JBL 2446 2" exit compression driver on a 12" long horn with 18"x18" mouth.
Re: Give us the "pitch"...9π ??? [message #49909 is a reply to message #49908] Tue, 22 August 2006 21:27 Go to previous messageGo to next message
what's the overall efficiency on this? I assume that combining the 12 and the 9 would be too much for the SET's, huh? Can't see them driving that sub...
Re: Give us the "pitch"...9π ??? [message #49910 is a reply to message #49908] Tue, 22 August 2006 21:28 Go to previous messageGo to previous message
ALRIGHT!!!! If I knock about 6 walls down in my house they would work perfect in the living room! I've got 10 foot ceilings so they should fit. Pump about 1200 watts into those puppies and BOOM!, really tick the neighbors off.
Previous Topic: New Horn Tweeters? (and any impact to 3 pi designs???)
Next Topic: Prosound Shootout
Current Time: Tue Jun 11 19:20:37 CDT 2024
