Home » Sponsored » Pi Speakers » OK Till E
OK Till E [message #46932] Fri, 20 May 2005 11:23 Go to next message
GarlandGarland is currently offline  GarlandGarland
I know you've put the motor run caps into your crossover and are really trying to be patient and are letting them break in for a few weeks before you pass judgement on them but please give us(me) a hint at what you think of them in your system! These suckers are interesting: I have a situation where 10 uF 370V GE's sound entirely different(better) than the exact same cap but rated 440uF (taller can). WTFDIK!
G.
Re: OK Till E [message #46933 is a reply to message #46932] Fri, 20 May 2005 12:59 Go to previous messageGo to next message
Sorry to derail your thread, but do you still have those really great looking four π's?
Still have 'em! - Still love 'em! [message #46934 is a reply to message #46933] Fri, 20 May 2005 16:02 Go to previous messageGo to next message
...and Wayne, thanks for the compliment! As an impulsive tweaker, I must say that little I have done has improved on the already great sound of your design. Oil caps in the crossover and felt on the dust caps of the Delta 15s have gained a bit of clarity and smoothness but still the original sound is still there in all it's awesomeness!
I only wish I had the corners for the corner horns!
Garland
Re: Hang in there Mr. G [message #46935 is a reply to message #46934] Sat, 21 May 2005 03:41 Go to previous messageGo to next message
Too many things going on I never went back to pick up the the 30uF's I had Grainger bring in for me. Which is a good thing 'cause I went back up to 1600 Hz from 1200 and now need 20uF's.
Have to make time next week and will report, fer sure.
Your speakers look so awesome! [message #46936 is a reply to message #46934] Sat, 21 May 2005 07:19 Go to previous messageGo to next message
Re: the corners for the corner horns [message #46937 is a reply to message #46934] Sat, 21 May 2005 11:35 Go to previous messageGo to next message
Does anybody think that false corners a-la the Klipschhorn recommendation are workable?
Re: the corners for the corner horns [message #46938 is a reply to message #46937] Sat, 21 May 2005 12:17 Go to previous messageGo to next message
I think it's a good idea in principle, it's just that they're so cumbersome. But you could surely stack a wall of concrete bricks to form a false wall that was more solid even than the permanent walls of most homes.
Re: concrete blocks [message #46939 is a reply to message #46938] Sat, 21 May 2005 14:25 Go to previous messageGo to next message
They'd be about as visually attractive as the rest of my audio-related endeavors
But I do wonder – I’ve read how bass is “lost” through flimsy construction. Klipsch said to build a 2X4 stub wall sheathed on each side. But is that really the effective? Are cinder blocks really required?
Re: concrete blocks [message #46940 is a reply to message #46939] Sat, 21 May 2005 14:40 Go to previous messageGo to next message
Certainly, if the walls are free to vibrate, then you'll lose some of your energy in making them move. Or worse, if they're not damped, they can make their own sound, making peaks from panel resonance.
Most times, the drywall in homes isn't very solid but it's damped pretty well from the insulation behind it. So that helps. In some instances, you'll find a wall or panel without insulation behind it. They're troublesome, because it sounds as hollow as it is.
Re: The test of time [message #46941 is a reply to message #46936] Sat, 21 May 2005 16:39 Go to previous messageGo to previous message
Still the most elegant, balanced-looking large box speaker on the planet.
Previous Topic: Eminence ASD 1001
Next Topic: pi 2 new tweeter upgrade help
Current Time: Wed Jun 05 03:55:25 CDT 2024
