Home » Sponsored » Pi Speakers » Woodfinishing experts...seeking advice
Woodfinishing experts...seeking advice [message #43099] Wed, 19 November 2003 11:24 Go to next message
jlharden is currently offline  jlharden
I've nearly decided on using the baltic birch ply for the corner cabinets. I don't have any hands on experience finishing birch ply and am going to defer to those that do. I don't want to darken the wood with stain and don't want the yellow look that is common with some woods after finishing. What are my options and what techniques have yielded the best looking results? Thanks! Jerrod
Re: Woodfinishing experts...seeking advice [message #43101 is a reply to message #43099] Wed, 19 November 2003 11:55 Go to previous messageGo to next message
My best advice is....test strips. Keep scraps of wood from construction and test finishes on them. I made Baltic Birch cabs and it didn't take stain very well. I used "Tried & True" products- few coats of its "Linseed Oil and varnish" product, with its "Linseed Oil and Beeswax" as a final coat, and they look very nice and are aging nicely. These products are very good, but I imagine other good oil finishes would look similar.
Re: Woodfinishing experts...seeking advice [message #43110 is a reply to message #43099] Wed, 19 November 2003 15:26 Go to previous messageGo to next message
Tightwad is currently offline  Tightwad
I'm a total hack, but I've made a couple projects.
I like the "Scandinavian" look of birch-veneer plywood with clear finish (see photo, not my work, but a good example).
I think clear urethane stuff works pretty well, just spread it on thin in many coats.
Also, be very careful about glue, especially on the edges. It can escape detection, and end up looking crappy after finishing.
Re: Water Base [message #43112 is a reply to message #43099] Wed, 19 November 2003 16:35 Go to previous messageGo to next message
If you want the finish to stay nuetral, clean, and colorless. The water base polyurathane's are going to be the best bet. Lacquers, oil's and especially varnish all carry an amber tone to enhance the grain and give the wood a warmth. All of these are going to become a more golden to amber colour with age. Water white lacquer's are less amber and designed to be now yellowing, so you have less aged look over time. The blonde shellac's can stay pretty clear but basically anything made with petrolium type products and distilates requiring alcohol or a thinner for cleanup is going tone out with age even when sheilded from UV.
The water base poly is easy to apply, easy to clean up and is as durable as the best of anything. The biggest problem with the water borne finishes, be it poly, lacquer or varnish. Is that the water borne does not do exactly what you are looking for. They have no amber tone unless it is added. They dont pop the grain in high figure woods and veneer, and they wont yellow, amber, tone out or show virtually any sine of age to give a petina or look of age and depth.
Get your self some Minwax water base poly and your birch wil stay as clear and blonde as you like. Use a non yellowing silcone wax after your all done and stay away from any paste wax or similar product that will deposit a film that can tone out.
Spraying finish is always best but if your going to brush then great results can be had with care. Buy a good brush and keep it clean as new and it will last a long long time. do some research on brush care. strain your finish as you use it. Dont use the finish out of the original can. Open the can, pour out what you need and close it up again.
The first coat is going to rais the grain a little. if you sand with 400 it will be less. It really doesnt matter because you HAVE to sand poly in between each coat. Poly and varnish have 0 burn in and require a mechanical bond from one film to the next. You must sand with 220 in between each coat if you want to achieve the best finish. So sand off the first coat since all the wood fibers will get locked down in all kinds of kamasutra type positions. apply a second coat, sand, apply a third coat, sand, apply a fourth coat if you like a smooth build. 3 coats might make you happy and it's a commercial standard. 4 or better coats with good sanding in beteen to make sure the surface is leveled and uniform can look dynamite.
If you want glossy gloss then your last coat needs to be heavenly perfect or you have a lot of rubbing to do, but if this type of "piano" finish is what your after this isnt the right stuff. Most folks like a fairly smooth satin with just a hint of gloss to it. For this I always use a gloss finish and rub it down to a satin. Sand your last coat with 400 paper, now steel wool using 0000 steel wool, and then apply wax.
One last note if you use a water borne finish. Do not use any stearated sand papers. Do not use any steel wool in between coats, and any of the scotch bright pads for rubbing and sanding are also a bad idea.
Bill
Re: Woodfinishing experts...seeking advice [message #43113 is a reply to message #43099] Wed, 19 November 2003 17:24 Go to previous messageGo to next message
Hey JL;
Martinelli knows most about finishing wood but I will chime in to say that on birch I think the wood looks like knockdown furniture with waterbase finish. Try some websites that deal with shellac; good shellac can be mixed to give any level of tint and imparts a nice organic glow to birch. Its really not hard to do either.
Re: Woodfinishing experts...seeking advice [message #43114 is a reply to message #43113] Wed, 19 November 2003 18:15 Go to previous messageGo to next message
Yeah, the water base stuff is pretty sterile insnt it! I've used it a on a couple different things and years later I look at them amazed that there just isnt anything to the finish other than clear. The advances in the water products gets better each year. There are some higher priced types out there that are acting more like a good finish. Some water borne lacquers even have complete burn in.
I've only played with shellac a few times. Maybe Epstein Has more info on the shellac too. I know he likes those and uses them often. When I retire I'll do more with the different types and maybe some french polish as well. For speed, durability and import to me, colour. You cant beat catylized lacquer. One birch my personal choice would be a spar varnish. I like the way it looks with a little time.
Bill
Re: Water Base [message #43122 is a reply to message #43112] Thu, 20 November 2003 09:37 Go to previous messageGo to next message
Thank you Bill,
Ask and you shall receive!....lots of great info, and I'll folllow the advice on the clear water based poly. I've been interested in experimenting with it anyway. I've done a lot of work with pre-cat laquers, but don't currently have access to the equipment. My shop equipment is very limited right now. You recommend the Minwax brand, is the satin preferable to gloss, or better to build up with gloss and rub the finish down to satin? Is the siliconized wax a liquid type? Thanks! Jerrod
Re:Olive Oil [message #43126 is a reply to message #43122] Thu, 20 November 2003 12:41 Go to previous messageGo to next message
Nah, maybe not!
But shellac, once you have the brushing strategy down on test pieces is really great for an undercoat. At least peruse the catalogues. There's super blonde, blonde, la-la-la, garnet and then a really dark one I can't remember. Still celebrating ugly spinster daughters engagement.
I think there's a shellac.com but Constantines.com and GarrettWade.com have good info as does Behlen and Mohawk. Thing about shellac is it's dead easy,really versatile, and is the best dang sealer on the planet. Even "Trust Fund Kids" like Martinelli who have spray equipment use shellac as a sealer against the dreaded "fish eye". Or should, right Bill?
Thing is, the Birch is darn near non-porous except where it isn't and there it's too dang porous so you really can get horrible blotching. Or a " plotcher" if it's the 'Crepitation Contest'.
So you need a sealer or pre-stain thang or sanding sealer. Shellac is all the above. Ya' haf ta' practise the technique tho' cause it dries right off the brush and so doeasn't "flow" from one stroke to the next. But don't be off=put. it's still easy.
And the warmth the other guy mentioned is there. I'd say use de-waxed Blonde and forget about it. Highly water reistant but not alcohol resistant so use the AOL coasters.
Creating is more like performing than listening
Re:Olive Oil [message #43129 is a reply to message #43126] Thu, 20 November 2003 13:28 Go to previous messageGo to next message
If I may offer there is a site called shellac.net that has it all!
And reasonably priced too.
Re:Olive Oil [message #43130 is a reply to message #43126] Thu, 20 November 2003 14:51 Go to previous messageGo to previous message
If you want to experiment with shellac, my local hardware store (the one besides H.D.) has a pack of 6 colors/types of shellac for $14.99- enough to experiment with and see if you like it and what color to get. Bill- you would like their spokeshaves and scrapers, not to mention their handmade Swedish axes.
Previous Topic: box design/plans for JBL 2226
Next Topic: Journal of a First-time Builder - Pt 4: Functioning Speakers x2!
Current Time: Wed Jun 12 08:30:40 CDT 2024
