A couple questions about Pi-alignment [message #42549] |
Tue, 23 September 2003 18:40 |
Tightwad
Messages: 41 Registered: May 2009
Baron |
I am designing an enclosure for a high-Q full-range driver, simple BR design. In terms of calculating the optimum enclosure volume, resonance, and bandwidth, is the Pi-align whitepaper the best source? I only ask since it is dated 1979, wondering if it is state-of-art for Pi-alignment. Also, in the formulas on page 5, I don't recognize some of the parameters from the typical T/S params. Anyway, any advice would be appreciated.
C4, B4, QB3 and EBS [message #42554 is a reply to message #42552] |
Wed, 24 September 2003 10:39 |
Messages: 18700 Registered: January 2001
If you're interested in looking at several alignments, I suggest reading Davies' T/S implementation, and studying the popular generalized alignments such as C4, B4, QB3 and EBS. Davies was the one responsible for suggesting a popular critically damped alignment, used in several modern software packages, and based on prior work by Thiele and Small. Thiele and Small described the relationships between motor cabinets and electro-mechanico-pneumatic specifications, but they focused mostly on the relationship and its effects on response, not so much on specific alignments. A couple of specific alignments were mentioned, but most popular alignments are implementations based on their prior work.
