Home » Sponsored » Pi Speakers » Pictures of the "corner horn"
Re: That is cool! [message #39458 is a reply to message #39455] Thu, 12 December 2002 17:04 Go to previous messageGo to next message
Actually I was more concerned about room dimensions than construction. I can't use a corner horn in my place 'cause of the stupid layout of my room (even the 4Pi's don't like that much) so it wouldn't be workable for a lot of us unfortunately!
Kelly
Re: Pictures of the "corner horn" [message #39459 is a reply to message #39443] Thu, 12 December 2002 17:18 Go to previous messageGo to next message
Cool, I like it.
Don't you have a leave a space between the cube and the wall so the sound can come out of the corner?
Bill
Re: Pictures of the "corner horn" [message #39460 is a reply to message #39459] Thu, 12 December 2002 17:35 Go to previous messageGo to next message
Michaelz is currently offline  Michaelz
Hi, Bill:
Yes, there is about 1/2 inch space between the cube and the walls and the floor.
Michael
Re: Pictures of the "corner horn" [message #39461 is a reply to message #39460] Thu, 12 December 2002 19:57 Go to previous messageGo to next message
Hi Michael
interesting. and that's enough space huh. most things ive seen using a corner as part of the horn are around 8"-10" space. This is a really interesting box you have going here.
Bill
Re: Pictures of the "corner horn" [message #39462 is a reply to message #39461] Fri, 13 December 2002 04:10 Go to previous messageGo to next message
This is probably a bit more than the horn throat size by ML Util.
very cool! [message #39468 is a reply to message #39443] Fri, 13 December 2002 21:33 Go to previous messageGo to next message
i'd love to hear them. you should bring them to lima.
cheers,
george
Re: very cool! [message #39472 is a reply to message #39468] Sat, 14 December 2002 07:05 Go to previous messageGo to next message
I wish I could. Helas, I am down here in Georgia.
Re: Wow! Very interesting! [message #39492 is a reply to message #39454] Mon, 16 December 2002 08:07 Go to previous messageGo to next message
Walt is currently offline  Walt
The volume of the rear chamber should change if another compression ratio is used. In fact this volume varies lineair with this ratio.
For some horns it really makes a difference if the volume is chosen wrong. Might cause 5-6dB bumps! Use McBean to model a rearloaded hyberbolic horn with:
l=2.8m
ah=75cm2
am=850cm2
In this case the volume should be kept as small as possible!
Best regards,
Walt
Re: Wow! Very interesting! [message #39493 is a reply to message #39492] Mon, 16 December 2002 12:25 Go to previous messageGo to next message
Hi, Walt:
Thanks for the input!
l=2.8m
ah=75cm2
am=850cm2
Could you please tell what ah and am (mouth area?) mean?
I used HornResp to model a conical horn for the "corner horn".
Actually, I calculated the vb (back chamber) and vf(front chamber volumes) and used the numbers in HornResp.
I just do not use the calculated front chamber volume yet. So if I need to conform to the numbers I would use Wayne's idea. See how small the throat area and the vaf are:
Input
fl = 15
fh = 150
fs = 20
qts = .21
qes =.31
qms = 2.2
vas = .82
QMC 6.816 (qmc is from calculation)
Output
vb = 0.177 m^3 = 6.25 feet^3
vaf = 0.0073 m^3 = 0.2578 feet^3
st = 0.064 m^2 = 0.687 feet^2
n = 36.39%
the vaf becomes bigger if fh is lower. I use these boxes as a subhorns so I will not reduce the vb (which will raise the fh and lower the n (efficiency). Another reason for choosing this vb volume is that I can get a volume around 6 feet^3 in a box shaped this way by using 4X8 board without much waste (a lot of 2X2 pieces are needed).
The way the "corner horns" are placed now gives a st of
0.85344 m^2 = 1.399308 feet^2 and probably a vaf of 2 feet^3. So I think I would use Wayne's idea to conform to the calculated st and vaf.
Maybe due to the lossy nature of the walls and the floors, all these numbers do not really apply. What really counts for me is the sound it makes. I got the room modes, but what other horn that goes this low would not in the same room?
Thanks!
Michael
Re: Wow! Very interesting! [message #39501 is a reply to message #39493] Tue, 17 December 2002 01:45 Go to previous message
Ah = cross sectional area at the beginning of the horn
Am = cross sectional area at the end of the horn
l = horn length
The numbers I gave correspond to a hyberbolic horn as it was descriped in a previous edition of the german magazine "Hobbyhifi" as you will model this horn you will see that in this case a too large volume will result in a non flat frequnecy response. In this case the volume should be kept as small as possible:
http://www.hobbyhifi.de/Archiv/02/04_02/04_02.html
Best regards,
Walt
Previous Topic: 2pi's
Next Topic: Pi-aligned line array?
Current Time: Tue Jun 04 04:12:20 CDT 2024
