Wayne, what do you think about this? [message #37086] |
Wed, 26 June 2002 13:43 |
Adam
Messages: 419 Registered: May 2009
Illuminati (1st Degree) |
Hey bud, I Pialigned a Seas Excel 7" for use as a midbass in vehicle, running down to 60 Hz. It came up with some somewhat odd results which plotted funny in my box program (it gave me a response peak), but maybe I just mistranslated them. Anyway, I tweaked it slightly from what Pialign gave me, I placed it in a 0.33 cuft tuned to 51 Hz. Gives me flat response to 50 Hz, which is fine in this case because it'll only be operating 60 Hz and up. Is there any chance you could check this out and tell me if this box design would still sound great for the midbass? This is one of the best midbass drivers in existance, but I've never heard of it being run in such a small enclosure before, and it strikes up a bit of worry. Since you have a ton of experience with these overdamped ported box alignments, I thought maybe you could help me out. Thanks bud. Here's the woofer specs: http://www.madisound.com/seas/e017.pdf Adam
This is a perfect motor for Scott's application [message #37087 is a reply to message #37086] |
Wed, 26 June 2002 15:11 |
Messages: 18695 Registered: January 2001
You've found an excellent motor for Scott's application. The system is optimally flat using this driver in a box the size needed, a quarter cubic foot. It's not terribly efficient, at 88dB/W/M. But that's normally the case with tiny woofers like this, and overall, it looks like one of the best solutions for the system. From the Seas W18EX001 specification sheet, the numbers shown are Vas=37 liters (1.31 cubic feet), Fts=31.0Hz and Qts=0.24. PiAlign values are then Vad=1.31, Frd=31.0 and Qd=4.17 and the recommended enclosure is 0.31 cubic feet and tuned to 48Hz. It is able to calculate a cabinet having actual resonance very close to this - 52Hz - using a 3/4" port that's 3/4" long, so that nice because it can be formed easily by drilling a 3/4" hole in 3/4" baffle material. All-in-all, PiAlign's recommendation is an excellent solution. A couple of other things are worth mentioning. You might notice that distortion rises substantially at low frequencies. It rises fast below 100Hz, where it is around 1%. By 50Hz, it is over 3% and climbing quickly into the double digits. Distortion is also rising at the other end of the spectrum, and breakup modes are severe at 4kHz. Performance up to 4kHz is quite sufficient and really, so is performance down to 50Hz. For a system of this size, I think it would compare favorably and work very well.
Re: This is a perfect motor for Scott's application [message #37089 is a reply to message #37087] |
Wed, 26 June 2002 16:20 |
Adam
Thanks Wayne! I was planning on crossing it at 1.2 kHz with an Image Dynamics horn, so the breakup modes won't be a problem. Also, like I mentioned in my particular app, it'll only be operating down to 60 Hz so I think distortion should be fine. This is one of the cleanest midbass drivers around. I think you can do better than it for the low bass, but it's still an impressive unit... Some of the lowest distortion figures around, twin copper shorting rings, magnesium cone, solid copper phase plug... Pialigning the driver (or at least a similar alignment) really seems to offer the extension I need down to 60 Hz, with big time power handling, no loss in sensitivity... Shoudl be great!! Much better than running the weaker motor version in a sealed box... Bleh. I was going to recommend this driver to Scott actually, the only thing that stopped me is it's $156 dollar price tag and it's 8 ohm impedance. Adam
Re: This is a perfect motor for Scott's application [message #37090 is a reply to message #37087] |
Wed, 26 June 2002 16:28 |
Adam
Oh, by the way, it's worth mentioning that it was tested in a sealed box, which really isn't wht that unit should be running in at all, with that qts. I imagine the distortion figures on the bottom end would be a little lower if it was measured ported perhaps? Adam
Re: You probably should at least try it [message #37097 is a reply to message #37095] |
Thu, 27 June 2002 12:25 |
Adam
Scott, if you want, I'm gonna be running four of these units later next month (august) as midbass drivers in enclosures almost identical to this. That's why I brought it up initially. If you want, I can let you know how the full range bass sounds if you dont' want to spend the money for a trial unit. Adam
Re: You probably should at least try it [message #37106 is a reply to message #37097] |
Fri, 28 June 2002 06:30 |
Scott
Messages: 24 Registered: May 2009
Chancellor |
It's not that I don't want to try one out. I actually have a box ready now. Understand guys, it's a money thing. I've actually been wanting to put another on the other side of my car, just don't want to spend the money for another driver right now.
