Home » Sponsored » Pi Speakers » tweeter compensation in active set-up
tweeter compensation in active set-up [message #35088] Tue, 12 February 2002 05:01 Go to next message
hi gang, now that i'm running an active x-over with my 4 pi's shouldn't i change the tweeters compensation network? there is no need to attenuate the tweeter because the x-over takes care of that, right? do i not simply need to simply boost the top octave response? which circuit do i use? am i not wasting power from my quad II's with this original network? wayne, if you can tell me what components i need to extend the top octave maybe Till E can do a sand illustration for me and i'll be all set.
thanks guys,
cheers,
george
does your active xover have HF eq built in? [message #35089 is a reply to message #35088] Tue, 12 February 2002 05:48 Go to previous messageGo to next message
If not, maybe leave the resistor network and bypass cap alone, to preserve the proper response Wayne designed for. Just remove the 1.6 kHz. xover board from the path, if you have not done so already. Set your level controls for the LF and HF outputs to unity, the speakers comp net will handle the level diff. for you.. If your amps are different, some level tweaking will still need to be done...make YOUR ears happy.
tweeter amp + will need to connect to where you soldered R1 and R2 to each other. the xover board HF + out is/was wired there.
tweeter amp - out will connect to the other end of R2, which is also connected to the - terminal of the HF driver. the xover board LF - out is/was wired there.
bass amp + out will wire directly to the + terminal of the woofer.
bass amp - out will wire directly to the - terminal of the woofer.
It would be simplest to remove the HF wires where they exit the xover board, then extend them back to the amp...that way you don't have to mess with R1/R2 solder joint, etc. at all. Same goes for the LF wires, remove the wires at the old xover board, and extend them back to the amp. Easy to fix back into the original config. later if needed. Good luck, Sam
Re: does your active xover have HF eq built in? [message #35090 is a reply to message #35089] Tue, 12 February 2002 05:57 Go to previous messageGo to next message
hi sam, the original eminence x-over was already removed. everything sounds fine and the output levels have been optimized on my rane x-over. my question is: am i not still attenuating the tweeter to match the woofers output with this original tweeter circuit and thus wasting valuable power?
thanks,
george
Re: does your active xover have HF eq built in? [message #35091 is a reply to message #35090] Tue, 12 February 2002 06:39 Go to previous messageGo to next message
When running an active crossover, remove the passive crossover, including the tweeter compensation circuit. At the preamp/crossover, provide tweeter EQ with the following curve:
Re: does your active xover have HF eq built in? [message #35092 is a reply to message #35091] Tue, 12 February 2002 06:52 Go to previous messageGo to next message
Wayne, what type of horn are the CH-3's? Constant directivity? The response graph in your papers doesn't show any HF rolloff other then the natural 3db of the driver. No worries, just curious.
Adam
are you driving the HF with the quad II's? [message #35093 is a reply to message #35090] Tue, 12 February 2002 07:14 Go to previous messageGo to next message
Then don't sweat the lost power, if the end result is a more linear freq. response. Sure, you don't have the intimate amp to voice coil interface like the bass driver, but hey, the HF is damped by the network, yes?
Later, you might wish to try learning about the opamps/active filters more, with an eye towards being able to tailor a gain stage to have the desired EQ characteristics the HF needs for being flat. Can also add a stage with low end eq for the bass.
For example, in my preamp, there is a "+6 dB at 50 Hz." contour circuit...all it is, is a cap and resistor in front of a gain stage. There is even a bread board type kit out now, to learn and play with these things. And web resources. Depends on how far down the road in this hobby you wish to travel.
Sounds like you already have your system pretty well sorted out for now. Sam
Re: does your active xover have HF eq built in? [message #35094 is a reply to message #35090] Tue, 12 February 2002 07:42 Go to previous messageGo to next message
Replay,
which rane x-over? My AC-23 has holes in the board for a cap correcting CD horn response. If you use a smaller cap you could compensate for a higher freq. The Rane manual covers this topic, but doesn't list frequencies higher than 6K. If you do not have a manual, Rane has all of this online.
Thomas (the latest Pi newby)
Re: does your active xover have HF eq built in? [message #35095 is a reply to message #35091] Tue, 12 February 2002 07:47 Go to previous messageGo to next message
hi wayne! my x-over is a rane ac22 2 way x-over with 24db/octave filters. there is no hi-freq eq, just low & high gain controls. should i purchase an eq to run between the x-over and amp thus enabling to correct the response curve of the psd2002? really the sound now is fine with your tweeter network installed, i'm just want to get the best sound possible.
cheers,
george
x-overs for dummies! wayne please translate [message #35097 is a reply to message #35094] Tue, 12 February 2002 08:09 Go to previous messageGo to next message
hi wayne, based on this chart what do you suggest?
thanks,
george
quad II's for the top, mission for the bottom (nt) [message #35098 is a reply to message #35093] Tue, 12 February 2002 08:24 Go to previous messageGo to previous message
Previous Topic: More active crossover questions
Next Topic: Day Two in the Life of a 4 Pi
Current Time: Tue Jun 11 19:43:22 CDT 2024
