Home » Audio » Group Build » Re:Boy; Now I GetTo Learn To Use That Bosch Plunge Router
Re:Boy; Now I GetTo Learn To Use That Bosch Plunge Router [message #31998] Tue, 19 September 2006 12:59 Go to next message
I bought last year that is still sitting in the case looking all new and stuff. I bought it on a whim but never bothered to use it yet. This is great to learn new things.
Except now I have to buy a Band Saw. By the time I'm done these horns are gonna run me a thousand bucks. So much for .99c vanes.
Now we need a very high quality Back-loaded bass horn to match. And a custom designed tube crossover for bi-amping.
Plus two PP 845 triode amps to drive the bass and a SE 300B for the HF.
Did I miss anything?
Thanks Garman for your continued efforts on behalf of this project all kidding aside.
You don't need no stinkin' bandsaw [message #32000 is a reply to message #31998] Tue, 19 September 2006 14:34 Go to previous messageGo to next message
Unless you're using 2" thick material, a regular old jigsaw will do fine. Get the cheapest saw and install the most expensive blade.
Re: You don't need no stinkin' bandsaw [message #32002 is a reply to message #32000] Tue, 19 September 2006 16:26 Go to previous messageGo to next message
Roger that G; I got the jigsaw now I'll buy the blade.
The bosch router [message #32004 is a reply to message #32002] Wed, 20 September 2006 14:10 Go to previous messageGo to next message
Leland Crooks is currently offline  Leland Crooks
is the second best thing in my shop, my Bosch sliding compound miter is the best. Smooth, sweet, awesome power. I am a bosch dealer, and absolutely love their tools.
BTW, the bosch jigsaw is hands down best on the market. Uses an odd blade however.
Re: The bosch router [message #32005 is a reply to message #32004] Wed, 20 September 2006 17:49 Go to previous messageGo to next message
Yes; I read the reviews in several publications before I bought my router and they all said the Bosch jigsaw was the best out there. Handplaner also.
Bosch saw [message #32006 is a reply to message #32004] Wed, 20 September 2006 20:08 Go to previous messageGo to next message
The only Bosch tool I own is their jam saw. I've never used it, but our subs swear by it.
Re:Boy; Now I GetTo Learn To Use That Bosch Plunge Router [message #32007 is a reply to message #31998] Wed, 20 September 2006 22:43 Go to previous messageGo to next message
I bought a Bosch 2.25 HP plunge router a couple of years ago - best damn tool I own.
Re: Bosch saw [message #32008 is a reply to message #32006] Thu, 21 September 2006 05:29 Go to previous messageGo to next message
Are they using it for an undercut saw? I get occasional calls for those, and they're too expensive to justify. I've looked at this and it would be more general purpose, but I thought it looked awkward.
Re:Boy; Now I GetTo Learn To Use That Bosch Plunge Router [message #32009 is a reply to message #32007] Thu, 21 September 2006 05:57 Go to previous messageGo to next message
Might be the same one. I had to give up the garage due to remodeling chores but now I can get back into the swing of the thing. Use it for this horn project ; the Smithy.
Re: Bosch saw [message #32027 is a reply to message #32008] Mon, 25 September 2006 07:38 Go to previous message
Yeah, the tile guys use it for an underust saw. None of the crews I've worked with in the past own one, but they sure love the fact that I have one.
Stupid me did not get the package that included the miter attachment. This would have saved a lot of time in 1/4 round installs and other small trim. There would be no getting up and going outside to cut on a miter saw. The cuts could be done right next to where it's getting installed. Over a couple of jobs it would have paid for itself in saved labour cost alone.....C
Previous Topic: Back to the Horn
Next Topic: 6A5 P-P #3
Current Time: Wed Jun 05 12:40:36 CDT 2024
