Home » Audio » Group Build » cathode followers: minimum input impedance configuration?
cathode followers: minimum input impedance configuration? [message #31869] Fri, 07 April 2006 17:30 Go to next message
Hey-Hey!!!,
I have built some linestages with cathode follower outputs. Straight triode, triode cascodes, and pentodes.
I saw a description of a linestage using the type 85 tube. It was described as having a cascode 6BL7 output stage. The 85 is a high plate Z, low-ish mu triode. Seems that this output buffer would present a minimal load to its plate.
How to manage the input capacitance? Will a screen grid have more capacitance to grid than the other options? Let me gues...depends on the screen grid...:)
cheers,
Douglas
Re: Douglas [message #31870 is a reply to message #31869] Wed, 19 April 2006 19:52 Go to previous messageGo to next message
Are you still looking for an SCA 35?
well now... [message #31871 is a reply to message #31870] Thu, 20 April 2006 04:25 Go to previous message
I would always like to have more gear. The question is usually, where am I going to put it. Answering this with a low acquisition price makes squeezing another one in easier.
Pentode at netscape Period com
Thanks for asking,
Douglas
Previous Topic: more Peerless engineering samples
Next Topic: gapped Iron
Current Time: Wed Jun 10 05:09:23 CDT 2026
