Re: An uncraftsman question-- Cabinet grade plywood [message #29807 is a reply to message #29805] |
Sun, 15 October 2006 17:21 |
Bill Epstein
Messages: 1088 Registered: May 2009 Location: Smoky Mts. USA
Illuminati (2nd Degree) |
Yeah, we've had that off and on for a few years @ $25-$30. It's Chinese, the quality of the grain varies but the construction is first rate. I've used a lot of it. If you really want a good deal, look for the top or bottom piece in the bunk which will always have indentations from the banding. Ask for a $10 (at least) discount. And if you see delamination on the edges, cut well away from it. That is it's weakness.
Re: An uncraftsman question-- Cabinet grade plywood [message #29811 is a reply to message #29810] |
Mon, 16 October 2006 19:33 |
Bill Epstein
Yup. Every biggish city has a distributor or three that sells to cabinet shops. They generally have laminates, cabinet hardware, paper-backed veneer and hardwood plywood. GP and Weyerhauser are just 2 of the names that have Walnut and oak for around $90, cherry and mahogany a bit more and even exotics. I bought 'Chinese Walnut' out of Columbus from DSI for $52 a sheeet which is quite nice. Good quality hardwood plywood and iron-on veneer edge-banding make using solid wood a wste of time and resources, at least for large speakers.
Re: An uncraftsman question-- Cabinet grade plywood [message #29813 is a reply to message #29812] |
Tue, 17 October 2006 10:37 |
lon
Messages: 760 Registered: May 2009
Thanks for the replies. I just figured that cabinet grade (cheapo stuff from HD might have less of the annoying "there's some plywood" figuring in the panels. One thing I found that should be more stable is those glued up panels at Menards (in the Midwest USA). They look like butcher block so I suppose it depends on how dutchy your decor is.
