Home » Audio » Home Theater » 7.1 surround
7.1 surround [message #28602] Tue, 17 October 2006 15:20 Go to next message
jonnyboy is currently offline  jonnyboy
anybody have any thoughts on whether to use dipoles or regular speakers for the sides in a 7.1 setup...my room is 26x13 and seating will be about 10-12 ft back....
Re: 7.1 surround [message #28604 is a reply to message #28602] Wed, 18 October 2006 15:31 Go to previous messageGo to next message
I think I'd prefer dipoles or horns. But understand that I generally prefer horns anyway, since I make them. The main thing for me is uniform directivity, not so much a narrow pattern, particularly in the surround positions. They're there to create ambience anyway, and to provide some directional details.
Re: 7.1 surround [message #28606 is a reply to message #28602] Fri, 03 November 2006 22:19 Go to previous messageGo to next message
John Chleapas is currently offline  John Chleapas
I am now just setting up my first 7.1 after been using 5.1 for a while now. I think the most important thing is to use similar/same type speakers for the sides that you use for the rest of your set up. You want them all to voice the same, right? I am moving from my vintage all JBL set up to an all Hales 7.1 set up. Well, 7 Hales and one JBL subwoofer. Good luck! John
Re: 7.1 surround [message #28607 is a reply to message #28606] Sat, 04 November 2006 05:37 Go to previous messageGo to next message
thanx for the input.. i have decided against using dipoles because after researching, i found for 7.1 music it is better to use normal speakers and my system will be used for both theater and multi channel listening. i ended up getting a great deal on a pair of new paradigm studio 100v3, i will be using studio 40v3 for the rear and hope to pick up some studio 20v3 for the center rears...
Re: 7.1 surround [message #28608 is a reply to message #28604] Wed, 15 November 2006 17:36 Go to previous messageGo to next message
But wouldn't dipoles be strange for music? I have not listend to multi-channel music yet, but I would think you would want a more direct sound, not sound just bouncing around?
Re: 7.1 surround [message #28609 is a reply to message #28608] Wed, 15 November 2006 19:05 Go to previous message
You'll actually have less reflected energy in the room when using dipoles or horns. They are more directional than other types of speakers.
Previous Topic: HDTV FTA receiver
Next Topic: HDTV FTA coolsat 7000
Current Time: Wed Jun 10 04:54:38 CDT 2026
