Ground Pounding Action, action, action! [message #28057 is a reply to message #28056] |
Tue, 02 August 2005 03:25 |
Messages: 18702 Registered: January 2001
Well guys, we're in. Tulsa Raceway has agreed to allow us to host the event there. The date is Friday, October 14th, from 10:00am to 6:00pm. The price is $10.00 for admission to the raceway, and for that, you can stay all day for the prosound event and through the evening for the racing event. After 6:00pm, the track will have car races. That night is test-n-tune, when racers are running and calibrating. You can even bring your car and run it if you want. There will be everything there from street cars to nitrous burning ground pounders. It will really be a lot of fun for the price, and you can come and go as you please through the day and evening. The racing complex has all the power we'll need, 110v, 220v even up to 480v three-phase. So we're set for power. The stadium seating on the north side of the track provides cover, so should we get rain, our equipment won't be exposed. I'm really looking forward to this. It should be a great time on several levels. We can test and examine our sound equipment all afternoon, and check out the cool cars all evening. Everyone is welcome, DIY and pros, so please come on out. If you need suggestions on hotels or anything else about the area, please contact me. Information is available on the website at www.ProsoundShootout.com. If you intend to be there and want to have your gear listed, please let me know and send some pics. I'll put it up so people can see who's coming. We'll also post photos and test results after the event.
General test plan [message #28058 is a reply to message #28057] |
Sat, 03 September 2005 23:45 |
A general test plan is listed below. The specific details of the test plan are specific to the test platform, which is probably going to be Praxis or LMS. David Lee has graciously offered to provide these test platforms and other assistance. 1) Impedance sweep, cold.2) Impulse response. 3) Frequency response w/SPL at 1W/1M, 10 Hz to 20 kHz (Measured at distance and corrected to 1M) 4) Frequency response (20 Hz - 200 Hz) w/SPL at 3dB increments to rated power or physical limits. (This will show heat compression and max SPL) 5) Distortion at 110dB (20 Hz - 200 Hz) and then at 3dB increments from there to rated power or physical limits. (This will indicate the practical limits of the system regarding usable maximum clean reproduction.) 6) Run heat soak signal 15 minutes at 80% power, repeat steps 4 and 5. 7) If required, processors can be applied and tests 2, 3, 4, 5 and 6 repeated. 8) Single horn tested first, pairs or groups tested next if desired. 9) Subjective listening test using a selection of identical program material played at a referenced sound level. 10) Subjective listening test using a selection of identical program material played at the maximum sound level of the loudspeakers.
All measurement will be taken from the same place. To save time and insure the least variation, the microphone will be placed at ground level and not moved. All cabinets will be placed on the same mark at the same distance from the microphone.
Re: General test plan [message #28065 is a reply to message #28064] |
Thu, 15 September 2005 07:21 |
Leland Crooks
Messages: 212 Registered: May 2009
Master |
Wayne, do you by chance have any of your heat sinks ready for HL10s? I find the whole idea interesting. I'm thinking of pulling a driver and taking some measurements to make a couple. The distance from the driver to the plate is pretty far in a tuba, so my plan is to radiate in the chamber, as the length would radiate most of it there anyway. Possibly turn a right angle to a sink mounted in the horn path .
