Home » Audio » Pro Sound » Vox Amp Issue
Vox Amp Issue [message #27602] Mon, 28 July 2008 00:39 Go to next message
Silent Mind is currently offline  Silent Mind
I have a AD100VT Valvetronix amp that I gig pretty hard with. It recently has been cutting in and out. I diagnosed that it is definitely the amp and not the guitar or cables. I was wondering if I need to replace the input jack or if it could be the Electro-Harmonix preamp tube. When playing I have to strike the strings very hard to get sound to come out and then it cuts out completely before fully fading out. Any help would be great!!!
Re: Vox Amp Issue [message #27603 is a reply to message #27602] Tue, 29 July 2008 12:10 Go to previous message
An easy test is to substitute and known good part and see if the symptoms change. The input tube is inexpensive enough I think it makes sense to buy one. Even if that's not what's bad, you can always use a spare tube.
Another thing that might be worth buying is a tube tester. You can find them on eBay.
Previous Topic: different amp heads and cabinets
Next Topic: alternative to '59 bassman
Current Time: Tue Jun 04 14:05:32 CDT 2024
