Hey i was wondering what the problem can be with my amp... I have had this Marshall amp for about 3 years but only tonight has it started acting weird...When playing the sound is pefectly fine but once and awhile it will fade in and out... can anyone help?
Wayne Parham Messages: 18700 Registered: January 2001
Clean the tube contacts, mechanical connections and potentiometers. I would use a flux remover or tuner cleaner made specifically for electronics. Hopefully, that's all you'll need. Might check the tubes too and make sure they're all fresh.
Good luck with that. I used to have an intermittent problem with my Peavey head, and sometimes the problem wouldn't happen when it was in the shop, so it took a couple tries to get it fixed.
