Home » Audio » Speaker » so I built these lines with a single tweeter
Re: so I built these lines with a single tweeter [message #24141 is a reply to message #24139] Sun, 27 January 2008 10:41 Go to previous messageGo to next message
Dave is currently offline  Dave
Wow, that sounds time consuming. You got great results though, where did you tune?
I like that idea of sinking the frame lip. I was thinking of making my first pass with the router the pass that makes the lip flush, then coming in and doing the hole. I can see how coming back after the holes are cut would be faster because you don't have to keep finding the pilot hole.
Re: your wife [message #24142 is a reply to message #24140] Sun, 27 January 2008 10:49 Go to previous messageGo to next message
Special music room would definitely net you a lot more slack.
Our basement isn't deep enough to build a floating floor and all that, so I'll have to wait for our next house to make one.
basement? [message #24143 is a reply to message #24142] Sun, 27 January 2008 10:57 Go to previous messageGo to next message
Marlboro
In about a year you can buy my current house, since my wife and i are moving to Mount Desert Island, Maine.....
Re: basement? [message #24144 is a reply to message #24143] Sun, 27 January 2008 15:22 Go to previous messageGo to next message
Is it a single story ranch with unfinished, yet finishable basement?
Also needs to be out in the country, I want it quiet outside in the evenings. I'd like a small outdoor amphitheater.
I love music outside, I've got a pair of NSB arrays with 9 tweeters mounted at sitting height for my back deck. The NSB.s and tweeters are mounted on the face, and the 2 sides are mounted to the face with 4 ft. long hinges. They are dipoles, and the hinges allow for constant tweaking. They need a subwoofer to cover from about 200Hz, I've got a couple of RS 180's I'm not using and a small plate amp that I'll use to cover the bottom end. Should be a neat little project coming up before the summer.
Re: so I built these lines with a single tweeter [message #24145 is a reply to message #24141] Mon, 28 January 2008 11:43 Go to previous messageGo to next message
Anonymous
I tuned to 100hz, four NSB per chamber [~1.5 cu. ft.}, 6" hole in
the back as the port. The WinISD models shows a peak in upper
midbass, I wanted this on purpose as I didn't expect much from the
NSB's as I wanted higher SPL levels. It works well, the upper midbass
is very strong - in room - and if it's too much, I can use the DCX
EQ to tame it. I can also plug the rear port with a fancy piece of
wood to make it a sealed box. I did this, but I liked the more
aggressive sound with the port.
Re: basement? [message #24146 is a reply to message #24144] Tue, 29 January 2008 05:31 Go to previous messageGo to next message
Marlboro
Where do you live now?
Re: basement? [message #24147 is a reply to message #24146] Tue, 29 January 2008 14:40 Go to previous messageGo to next message
Near Dayton Ohio, about 15 minutes from Parts Express.
Re: basement? [message #24148 is a reply to message #24147] Thu, 31 January 2008 09:26 Go to previous messageGo to next message
Hey. I live near in West Chester, OH. We should hook up. I host events every once in a while. I had David Janszen over a few months ago....Colin
Re: basement? [message #24149 is a reply to message #24148] Fri, 01 February 2008 07:07 Go to previous messageGo to next message
Marlboro
Who is David and Arthur Janzen?
Janszen $32,000 speakers [message #24150 is a reply to message #24148] Fri, 01 February 2008 07:12 Go to previous messageGo to previous message
Marlboro
I don't think that my $1400 speaker system total cost including electronic crossovers, three amps, one preamp and a cd player, and all the speakers would be in the same league as Janszen's $32,000 speakers, nor would he consider them to be in the same league.
I get in enough trouble with Rick Craig by telling him that my system performs as well as his $8000 systems.
Previous Topic: Favorite dome tweeters
Next Topic: Speakerlab K Horn
Current Time: Mon Jun 03 23:29:45 CDT 2024
