Home » Audio » Speaker » Equalization in Arrays
Equalization in Arrays [message #22749] Tue, 26 July 2005 06:49 Go to next message
Brent S is currently offline  Brent S
Are people using Equalization in arrays very much? How about active crossovers?
It would seem that when one is putting a bunch of small drivers together, all of which are not really very expensive individually, that equalization would be a central part of the equation. But I never hear anything about it.
Re: Equalization in Arrays [message #22750 is a reply to message #22749] Tue, 26 July 2005 10:32 Go to previous messageGo to next message
Anonymous
Yes.
For the NSB/PT2 array {4" midwoofers w/planer tweeters) I'm using an
active setup with the Behringer DCX2496. The first thing I do is
tune everything by ear using common sense. I sweep the active
crossover range and listen to the music to find the sweet spot I
like. I also do individual driver tests where I only listen to
tweeters and then only listen to the midrange so see if I can hear
problems in this range of frequencies that I selected to make sure
there is nothing bad.
After doing all these listening tests, I prefered a PT2 crossover
frequency between 1.5khz - 2khz using the 48dB slope. The steeper
slope filters out midrange crud and improves the image.
For the NSB high pass I found that 65hz using the 48dB slope worked
nice. I just sweeped the range and listened to the bass and noted
cone excursion at high power to make sure I'm within safety range of
the drivers.
I set the EQ depending on mood, genre of music, and per individual
CD as bad recordings need to be fixed. I'll use a simple example.
For jazz/vocals, I cut the ~150hz region on the midrange output
~6dB as ported NSB's are giving me crazy midbass where things falls
off the TV. The Radio Shack meter peaked at 126dB on a bass guitar
listening test.
The tweeter output I boost 6dB @ 8khz shelving high pass. This gives
me that crispy top end I like when listening to cymbals.
To smooth out the midrange sound, I use an input EQ using a Q of 1
and cut the 1khz band about 4.5 to 6dB. 32 midrange drivers is alot
of midrange sound and the room is small so I need to tame this down
a little.
Next, I adjust the output levels because I'm using two different
amplifiers, one a home amp, the other a proamp so I need to adjust
the midrange level in relation to the tweeter level. In my case
I need to adjust the midrange level -6dB to match the PT2.
Last, I added delay to one channel, about 15mS to add 'concert hall'
effect which gives the music depth. Some genres of music do better
with no more than 25mS delay.
For death metal music where headbanging is required, I set the
EQ closer to 'zero'. I turn off the midbass EQ, turn off the tweeter
EQ, adjust the input EQ to -3dB cut, adjust the midrange level
anywhere from zero to -3dB. The midbass boom is appreciated in this
genre of music.
Re: Equalization in Arrays [message #22751 is a reply to message #22750] Tue, 26 July 2005 13:10 Go to previous messageGo to next message
What kind of equalizer should I use? How much should I pay?
Have you ever bought anything on ebay?
Re: Equalization in Arrays [message #22752 is a reply to message #22751] Tue, 26 July 2005 14:29 Go to previous messageGo to next message
Anonymous
The classic graphic EQ is nice. More bands {sliders} = more
tweakability and it's more of a general purpose EQ. The parametric
EQ is more specialized, usually used to fix specific problem areas.
Both work.
The next issue is whether you buy home audio gear or pro audio
gear. You have to figure out your front end electronics as
pro audio interfaces a little different than home audio. If you have
home audio gear try looking for affordable home audio EQ's. I chose the pro audio route because Behringer is hard to beat from a
price/performance point of view. You just have to design your front
end around pro audio.
The DCX2496 is a pro audio piece of equipment, it's a digital
crossover with some parametric EQ and other stuff. Cost on
these is $250 shipped. The DEQ2496 is specifically an EQ. I haven't
checked home audio gear recently so I can't point you in a direction
other than maybe http://www.audiocontrol.com
Buy from a reputable seller.
Re: Equalization in Arrays [message #22753 is a reply to message #22752] Wed, 27 July 2005 15:48 Go to previous messageGo to next message
One thing I've found with these cheapy drivers is that they have very good response characteristics, they just won't handle a lot of power. When you use a lot of them to overcome the power limitations you end up with a speaker that I've found needs very little, if any, EQ. If I was going to go to the trouble of getting an EQ I'd go with the DCX and bi-amp the system. One thing these dual lines do like is high order crossovers, and the 48dB slope in the DCX seems ideal for the job. The built in 31 band EQ will get that response flatter than flat and with the autoEQ function it does all the work for you and corrects for room response at the same time, including your sub. It does mean you'll need another amp for the tweeter line, but with the sensitivity being as good as it is ten watts ought to do it.
Re: Equalization in Arrays [message #22762 is a reply to message #22750] Thu, 04 August 2005 02:01 Go to previous messageGo to next message
Zene Gillette is currently offline  Zene Gillette
Great post. Was considering the DCX2496 for the same type array. Was there any downside to it like noise/distortion or whatever that you could tell? Zene
Re: Equalization in Arrays [message #22818 is a reply to message #22753] Sat, 24 September 2005 08:25 Go to previous message
justinc is currently offline  justinc
How do you feel about using eq for good drivers? Im working on an array using the focal polyglass line 6.5" and a single fountek. Im deciding on whether to just design a passive xover and use a deq2496(the auto eq looks nice!), or go active and get a dcx2496. I am probably going to test out the new behringer a500 amplifiers with these speakers. I would only use one if I go with the deq, but will need 2 of them if i go with the dcx. So I figure it will cost about the same price for either option. Does the dcx provide enough eq in itself? one of the main things I would like to eq up is the low end response of the mids because i will be going with a rather small box. thanks for any help/input on these devices
justin
Previous Topic: Electrical filters and Acoustic Filters
Next Topic: Tapering Articulated Arrays
Current Time: Sun Jun 02 01:05:33 CDT 2024
