Home » Audio » Speaker » Getting test system soon
Getting test system soon [message #17490] Tue, 25 January 2005 08:15 Go to next message
adavis464 is currently offline  adavis464
Hi Wayne I like the discussion on how people miss use data(or the potental for disinformation using test data)I hope to avoid this.So when I start I will post here If thats ok.It should be a great learning experience and loads of fun Regards Tim
Re: Getting test system soon [message #17492 is a reply to message #17490] Tue, 25 January 2005 14:16 Go to previous messageGo to next message
We had a little discussion about the promises and pitfalls in the Measurement forum. Be sure and post your results there too.
Re: Getting test system soon [message #17506 is a reply to message #17492] Thu, 27 January 2005 07:28 Go to previous messageGo to next message
Wayne
I am going to take this opportunity to criticize, again, a point that you keep making regarding measurements.
Physical measurements are not a subjective thing and if done correctly are not subject to variations based on the implimenters bias. Now that said, interpretation of the data is more subjective AND making "correct" measurements is not easy. But I take strong exception to your position that someone making their own measurements is invalid and/or not believeable.
If the test setup, technique, equipment, etc. are all described, then I will look at anyones data because the validity can be critiqued from this information (assuming that it is honest and accurate!). I am not a big measurements person (contrary to past posts), I am far more theroetically inclined. Proposing a design - based on theory or models - testing it and finding a high degree of correlation lends a great deal of validity to design concepts. Far more than if the design had not been tested.
Now I am strongly opposed to testing as a means to a design. That does not necessarily ever lead to an optimum - one simply gets tired of testing and says "Well, looks good to me!" Testing should simply be a confirmation of what you expect - you should not see anything unexpected - the results should be completly predictable. If they are not then there is something that is not understood and that aspect needs further investigation until it is understood. The iterative work to the optimum is done with theory (models, math, whatever) and simply confirmed at the end with some measurements.
There are set rule to observation. [message #17507 is a reply to message #17506] Thu, 27 January 2005 08:15 Go to previous messageGo to next message
Hi Earl Yes that is the base I think for all scienitifc evaluation that I learned form grade school on.The problems start when trying to measure or observe an event not based on any solide theory.Regards Tim
Re: Getting test system soon [message #17511 is a reply to message #17506] Thu, 27 January 2005 17:15 Go to previous messageGo to next message
Hi Earl,
I'm not going to belabor this issue, but I'd like to make what I think is an obvious point. You wrote:
>> bias.
The two key things here are "done correctly" and "implementer's bias." There are those that have the inclination but not the ability, either because of lack of equipment or facilities or whatever. And we've also seen people that are eager to make a point throw out datasets unfavorable to the point they want to make. An obvious example is the marketing department of a loudspeaker company making sure their published charts show only their products best features or possibly even exaggerated claims.
Wayne
Re: Getting test system soon [message #17513 is a reply to message #17511] Thu, 27 January 2005 18:01 Go to previous messageGo to next message
Wayne
I'll repeat again - the existance of unscrupulous people is no reason to assume that everyone is that way. Because valid and useful measurements can be made it is prudent to first assume the positive and, at worst, be a little cautious with the unknown experimentor.
Re: opposed to testing as a means to a design [message #17521 is a reply to message #17506] Sat, 29 January 2005 06:00 Go to previous message
You know, this is possibly the dumbest thing I ever heard.
There were an awful lot of cars and trucks built between the first internal combustion engine and a comprehensive CFD model of in-cylinder combustion.
The Brooklyn Bridge still stands in daily use today despite the problems in metallurgy with the cables that weren’t even somewhat understood until 50 or more years later.
You really think the pyramids were built on a complete mathematical model? Or that DeForest had it all down pat with the first audion?
The only reason loudspeakers lend themselves to extensive modeling is that they are such simple machines – and even then the level of confusion and disparity of results is breathtaking.
Previous Topic: Minor MG3.6R Crossover Upgrade
Next Topic: Fostex f120a
Current Time: Thu Jun 13 11:26:12 CDT 2024
