Home » Audio » Speaker » My 30hz basshorn with 2226h
My 30hz basshorn with 2226h [message #16319] Fri, 09 April 2004 09:02 Go to next message
Hi all
So i was thinking-i have a 2226 on ported box(33hz 175L) ,and adrian mentioned to me that it has a similar response to the lab12 on a larger horn,so why buy a woofer when the existing one works.
240watts=130db spl with 2226 on 490L 30hz horn
this way
-i can add more or less volume easily ontop,independant of horn length
-i can inspect woofer/replace
-ease of construction
(btw im selling my car so its no use designing a small labhorn for it)
btw [message #16320 is a reply to message #16319] Fri, 09 April 2004 09:04 Go to previous messageGo to next message
notice the Fr,u can tell the horn would love about 10,000sq cm and a huge length too,but thats just not possible,im going to go live in a flat and use this thing as a piece of furniture :-)
Re: My 30hz basshorn with 2226h [message #16321 is a reply to message #16319] Fri, 09 April 2004 09:41 Go to previous messageGo to next message
Murilo is currently offline  Murilo
I would construct the horn first, listen to it and only later decide if the extra 15 dB are really wanted. You may be happy without the 350 w amp :)
And with such a big enclosure, don't forget about bracing...
In fact it doesn't seem big at all if I compare against my 2k litter space :)
Re: My 30hz basshorn with 2226h [message #16334 is a reply to message #16319] Fri, 09 April 2004 15:32 Go to previous messageGo to next message
That response curve looks pretty good. And I love those 2226's. Great performance and build quality.
Re: My 30hz basshorn with 2226h [message #16341 is a reply to message #16319] Sat, 10 April 2004 00:02 Go to previous messageGo to next message
I'd definitly do the 2226 horn - why do a LAB12 horn when you can make one with a woofer you already have! It does 30Hz adequately and is a good woofer so I expect it will be one nice sub.
I better add the mouth brace in on mine now :P
I'll make three basshorns, one for my 18LW1400, and one each for my pair of 2225's :P haha. Nawww.... the 2225's stay in the towers.
Re: My 30hz basshorn with 2226h [message #16342 is a reply to message #16319] Sat, 10 April 2004 04:19 Go to previous messageGo to next message
Hi Mike:
If you don't mind, what does the input dialog look like? (throat, width, etc...?)
Options [message #16349 is a reply to message #16334] Sun, 11 April 2004 07:16 Go to previous messageGo to next message
Its nice to know its possible,and do-able! Im amazed the small mouth works so well in a corner.
someday il get SW and mic and measure the distortion ,see what i get. i think that the wm-60 will provide something of a measurement anyway.
WHen i have a measurement system setup,il have a fit of measurements-tv speaker,pc speakers,car,home,jbl 15",digitor horn :p
What il do-see about a flat first! -i may not have room for a corner horn if my room is 2x4m :-) then i may only have room for a 12" in 3cubes :-S
then make a choice after that :-)
Cheers!
Re: My 30hz basshorn with 2226h [message #16361 is a reply to message #16319] Mon, 12 April 2004 09:10 Go to previous message
Previous Topic: Subwoofer Horn
Next Topic: Double-Blind test proves conclusively Fostex 103E is a horrible liddle squawker!
Current Time: Mon Jun 10 20:26:55 CDT 2024
