Home » Audio » Source » Digitizing Audio
Digitizing Audio [message #14467] Sat, 12 April 2008 04:16 Go to next message
Jim R. Daley is currently offline  Jim R. Daley
I want to digitize some of my old reel-to-reel tapes to be burned to CD's and I am wondering where to set levels for the best digitizing. The tape machine has a level control that affects the line output and the computer's sound card has a level setting applet for the line in jacks. Is it better to set the PC's level at max and use the tape machine's level, providing of course that I don't cause clipping or other distortion?
Re: Digitizing Audio [message #14468 is a reply to message #14467] Sat, 12 April 2008 15:35 Go to previous message
Best thing is to set the output level as high as possible that won't overdrive the input. Check peak levels for clipping and then back down just a tiny bit to make sure.
The reason you want the output drive as high as possible is this makes the signal to noise ratio as high as possible.
Previous Topic: Aiwa PX-E855U Tracking on LPs
Next Topic: MA Cotter Co Pickup Transfromer
Current Time: Tue Jun 09 04:44:23 CDT 2026
