Home » Audio » Source » Loosing one channel of sound
Loosing one channel of sound [message #13689] Mon, 30 June 2008 02:48 Go to next message
Roger is currently offline  Roger
Can sound one tell me what might cause one channel of sound to go out on a Rega PL 2 turntable. Is it more likely in my turntable or amp?
Re: Loosing one channel of sound [message #13691 is a reply to message #13689] Thu, 03 July 2008 14:39 Go to previous message
Could be anything. Here's an easy test to narrow down whether it's in the turntable or the amp: With the amplifier on and at a medium to low volume level, disconnect both channels from the turntable and plug in just the tip of the RCA plug on one channel. You should hear hum on that channel. Try this with both channels and if you hear hum on both sides, the amp is probably good. If so, check the wires to the cartridge and make sure they're not broken.
Previous Topic: Technics Direct Drive Automatic drop broken!
Next Topic: Gemini TT02 DD - Slow Start
Current Time: Wed Jun 10 04:57:44 CDT 2026
