Home » Audio » Source » Aiwa PX-E850 motor problem
Aiwa PX-E850 motor problem [message #13622] Sat, 05 January 2008 15:13 Go to next message
Sean is currently offline  Sean
I just got a "working" turntable on ebay. I put the belt around the spindle and then could not get the motor to turn. Is there anything I can try before trying to get a refund? Thanks!
Re: Aiwa PX-E850 motor problem [message #13626 is a reply to message #13622] Sun, 06 January 2008 20:47 Go to previous messageGo to next message
real_one is currently offline  real_one
Does the platter spin freely? If so, the motor should have no trouble turning it when the belt is installed properly. Check the platter and double check you have the belt on right.
Re: Aiwa PX-E850 motor problem [message #13627 is a reply to message #13626] Mon, 07 January 2008 12:30 Go to previous messageGo to next message
I think that the lubrication was gunked up once i got it spinning it hasnt had a problem. Now I just need to replace the needle, thanks!
Re: Aiwa PX-E850 motor problem [message #13654 is a reply to message #13627] Mon, 18 February 2008 16:27 Go to previous message
Now it spins to fast, any ideas?
Previous Topic: 100,000 ohms!
Next Topic: SONY PS-LX2 VS DUAL 1019
Current Time: Wed Jun 12 18:27:34 CDT 2024
