Very Good Construction article [message #10408] |
Sat, 25 February 2006 18:36 ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Manualblock
Messages: 4973 Registered: May 2009
Illuminati (13th Degree) |
Rod Elliott has a good article in this months Practicle Electronics detailing how to construct his 3 way active crossover. It is very thorough and well written; even to the point of allowing a first timer to build this unit.
Re: Very Good Construction article [message #10415 is a reply to message #10410] |
Fri, 03 March 2006 20:59 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Manualblock
You know G-Man; this is a linkwitz-riley but it is a three way design. Last year I bought his original x-over board, his boards are only a couple bucks each but I haven't done anything with it yet and If I remmember without looking mine was the po9. I am leafing through the article but I can't find any reference to a model number. Let me search the thing; there has to be a model number somewhere. This article is a really complete and thorough build description with wiring shots and everything. It looks as if you can buy it as a kit but I don't see a source reference. I'll let you know. How's the chip amp project coming?
Re: Very Good Construction article [message #10416 is a reply to message #10415] |
Sun, 05 March 2006 20:51 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
GarMan
Messages: 960 Registered: May 2009
Illuminati (2nd Degree) |
I think it's funny how you go all the way to Australia for your projects when you can get some world-class boards right next door from Marchand in Rochester. I'm working on several chip projects simutaneously. Rotating them depending on what parts have come in and what I'm in the mood for. Finished wiring up a Carlos-Snubberized PS and a pair of LM3875. Let me tell you. Stop playing around with your itzy-bitzy power supply from the "classic" GC design and move up to the big boys. Huge difference in the weight of your sound. Big improvement on the midbass and sub-bass with no ill-effect on midrange. I've also finished plugging 2 out the 4 LM3886-based boards I ordered from Marchand (2 channels per board). Tried them out on the Snubbed-PS and I love them. I'll give more detail as the project progress. g.
Re: Very Good Construction article [message #10418 is a reply to message #10417] |
Mon, 06 March 2006 08:08 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
GarMan
MB, Does the $90 include powersupply? If so, that's a great deal. Marchand's prices aren't pricey. I just looked at ESP's pricing for boards and they're in the same ballpark ($20-$30). What I can say is that Marchand's boards are very high quality. Thick and rigid, double-side and teflon coated. The brackets and heatsinks you can order with his amp boards are drilled and tapped to fit the boards perfectly. Marchand's version of the GC (PM21) is available as a stereo board for just $20. $100 gets you all the parts and the board. Sounds a bit pricey, but the design gives you the flexibility to run the amp with inverting, non-inverting, or differential inputs after it's been assembled. You can also get a power supply unit that includes a 160VA toriodal with 20,000uF per rail for another $100. I know this sounds like a commerical for Phil, but I think his stuff has been overlooked and underrated. g.
Re: Very Good Construction article [message #10420 is a reply to message #10419] |
Mon, 06 March 2006 10:49 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
GarMan
No setup yet. What I would like to end up with is two 4-channel amps based on the four Marchand boards. I see these boards as a very cheap and easy way to build a set of high quality multi-channel amps that I can use to experiment with various set ups. Bridging, paralleling, active XO, home theater, etc. The second project I'm working on is an all-chip integrated amp, based on a pair of "classic" GC and opamp-based preamp with tone control and separate opamp headphone amp. The theme of this project is "how good can an all chip system be without using "boutique" components. g.
