Re: No size limit on HT subwoofer, help please
[ PiSpeakers Forum ] [ Help ]
Posted by Wayne Parham [ 70.234.137.192 ] on January 06, 2008 at 19:52:43:
In Reply to: Re: No size limit on HT subwoofer, help please posted by Rick P on January 06, 2008 at 17:19:09:
No, the 12π is not suitable for use under 30Hz. I wouldn't recommend any horn for use at the frequencies you're talking about. I suggest a large driver with low Fs, or more likely several of them. For use at infrasonic bass frequencies, you really need low resonance and high displacement. Infinite baffle mounted in a wall or ceiling would probably be a good way to go.
