Re: 4Pi with feet [message #78449 is a reply to message #78127] Mon, 25 November 2013 15:16 Go to previous messageGo to next message
Hi Wayne,
After reading all of this positive reviews of everybody building 4 Pi's, I would like also to get the plans for 4 Pi and start slowly collecting the parts needed for 4Pi. Still not sure if I'll start with entry level ( all Eminence drivers ) or just wait for a very long time and go for upgraded version...
Best regards,
Max
Re: 4Pi with feet [message #78450 is a reply to message #78449] Mon, 25 November 2013 17:12 Go to previous messageGo to next message
You've got mail!
Re: 4Pi with feet [message #78454 is a reply to message #78450] Tue, 26 November 2013 15:13 Go to previous messageGo to next message
Thanks Wayne! Smile
Re: 4Pi with feet [message #78462 is a reply to message #78454] Wed, 27 November 2013 07:16 Go to previous messageGo to next message
Guys,
Next week I'll post some photos with the grills I'm working on The woofers are breaking in now Smile
I have a question on inductors, I've found on parts express 1.5mH, 1.0mH, but not 0.5mH 15AWG air core inductors. Can I use 0.47 or 0.55?
http://www.parts-express.com/jantzen-047mh-15-awg-air-core-inductor--255-408
Re: 4Pi with feet [message #78464 is a reply to message #78462] Wed, 27 November 2013 08:53 Go to previous messageGo to next message
Yes, go with 0.47mH.
Re: 4Pi with feet [message #78482 is a reply to message #78464] Thu, 28 November 2013 21:34 Go to previous messageGo to next message
Vox grills arrived, I'll start the grills now.
I've noticed that when I made the recessed routing for the horn to make the front very flat I ended with the horn about 6mm forward than the original plans. Is this ok? They look great and sound the same so I think it ok, but I'm not an expert.
Happy Thanksgiving!
Re: 4Pi with feet [message #78484 is a reply to message #78482] Fri, 29 November 2013 08:48 Go to previous messageGo to next message
Yes, that 1/4" shift only amounts to about 2°. It's totally fine.
Re: 4Pi with feet [message #78494 is a reply to message #78127] Sun, 01 December 2013 01:45 Go to previous messageGo to next message
dmeckstr is currently offline  dmeckstr
Lucas,
I love how you did these and your woodwork is really great too! I have been planning to build some of these for a long time now, but it's ok that I didn' get to it, since now I can steal your design!!
David
Re: 4Pi with feet [message #78496 is a reply to message #78494] Sun, 01 December 2013 08:16 Go to previous messageGo to next message
Hehe, you are welcome David!
If you need help just ask. I think the feets looks great, you just have to continue the side panels with the tilt you like and then add some mdf sheets under to make them solid. I made them 3"x3", but I can check the heights if you want.
The binding post at the bottom is a nice detail too.
I forgot to put some magnets under the veneer so now I will have some magnets on the front, as I won't veneer again, at least not this year!
Good luck David!
Re: 4Pi with feet [message #78544 is a reply to message #78127] Wed, 04 December 2013 19:29 Go to previous messageGo to previous message
Really nice looking build! I like the subtle slant to the cabinets.
VIRIBUS MARI VICTORIA
Current Time: Wed May 15 11:25:34 CDT 2024
